Hf CRX Timing Mark
Old Aug 30, 2005 | 08:12 PM
smash fascism's Avatar
Default Hf CRX Timing Mark
Hey, I just bought a 91 crx Hf with a broken timing belt. on the cam gear there is one long slot off centered, im assuming this is the timing mark. where does that need to be pointing? twords the fire wall? I would also like to know the chances of my valves being bent...... I have heard these arnt common for bending valves.
Thanks in advance
Matt
Old Aug 30, 2005 | 08:40 PM
jlicrx's Avatar
Default Re: Hf CRX Timing Mark (smash fascism)
Si, DX and HF use same timing gear - there are 3 marks, 2 directly across from each other with "UP" mark up and one at about 7 o'clock - the one at 7 o'clock is the mark used for D16A6 Si timing and lines up with mark on back of timing cover - the 2 marks directly across from each other are used on the D15 DX and HF - line them up with the top surface of the head
crooked muffler
30
Mar 3, 2006 05:31 PM
thao4life
Jul 17, 2003 04:46 PM
jjac
Jan 6, 2002 07:39 PM
