Good recommended bore size for ITR Throttle body?
Old Aug 30, 2005 | 08:04 PM
Junkyard2000's Avatar
Default Good recommended bore size for ITR Throttle body?
setup:
jdm b16 i/h/e/cams
Im gonna be using it with the AEBS manifold which has a 65mm inlet. Stock ITR is 66-62 correct? So would it be best to bore it out to 65 as well?
Old Aug 30, 2005 | 08:07 PM
JDMSiGuy17's Avatar
Default Re: Good recommended bore size for ITR Throttle body? (Junkyard2000)
i would say that sounds like a good plan! maxbore on here has many ref here on h-t.
Old Aug 30, 2005 | 09:50 PM
Default Re: Good recommended bore size for ITR Throttle body? (JDMSiGuy17)
What about getting a 70-65 tapered bore? Or is 70 too big? My intake is 3in if that makes a difference
Old Aug 31, 2005 | 08:17 AM
Rollo Lawson's Avatar
don't touch it. just put it on and done. your set up is basic.
Old Aug 31, 2005 | 10:15 AM
MikeSarr_GSR's Avatar
Default Re: (B16C1)
I agree with that, when you get a bit more on there you could go ahead
and match it to the IM. That seems to work well
Old Aug 31, 2005 | 08:27 PM
Default Re: (MikeSarr_GSR)
yea im probly gonna get some head work done so ill do it then. Tahnks
Old Sep 1, 2005 | 07:44 PM
Default Re: (e9)
so do i bore it or not?
86si
21
Jun 12, 2007 02:44 AM
civicjdmb16a
Jul 8, 2003 02:02 PM
Beave0101
May 20, 2003 12:03 AM
JohnnysEG
May 19, 2003 08:57 PM
typer694
Jan 2, 2002 03:25 PM
