Suspension & Brakes Theory, alignment, spring rates....
Brake fuild ATE vs. Motul
Old Aug 30, 2005 | 07:36 PM
kaiba's Avatar
Default Brake fuild ATE vs. Motul
After alot of searching i have narrow down to my last two option of brake fuild. ATE super blue and Motul RBF 600.
I would like some feed back and experience from people who have use them before. I wanna know the pro and con.
Basically i wanna use if for daily drive + weekend autoX and HPDE.
Old Aug 30, 2005 | 10:28 PM
bad-monkey's Avatar
both should be fine for what you want to do.
the motul has a better boiling point, the ATE is easier to bleed/flush b/c of the blue color.
i think the ATE is slightly cheaper, but they're both good fluids.
i use motul.
Old Aug 30, 2005 | 11:48 PM
jisu009's Avatar
Default Re: (bad-monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey &raquo;</TD></TR><TR><TD CLASS="quote">both should be fine for what you want to do.
i use motul.</TD></TR></TABLE>
exactly what I would have said.
Old Aug 31, 2005 | 08:19 AM
98EJ's Avatar
Default Re: Brake fuild ATE vs. Motul (kaiba)
The Motul will have to be bled more often as it absorbs moisture much faster than the ATE.
Old Aug 31, 2005 | 10:03 AM
anotheredhatch's Avatar
i love super blue
cheaper and more practical for a street/track car
and its always a blast trying to decipher the label on the side of the can,try it you will laugh your a$$ off.
PossibleDX
Suspension & Brakes
11
Jul 9, 2013 07:20 PM
Tennobanzai
Suspension & Brakes
10
Jan 7, 2013 02:01 PM
cdn_cajun
Suspension & Brakes
Jan 28, 2009 02:06 PM
1_slow_crx
Aug 16, 2006 01:55 PM
