Recommend me a sub: how's the Infinity Kappa Perfect?
Old Aug 30, 2005 | 06:46 PM
JDubya's Avatar
Default Recommend me a sub: how's the Infinity Kappa Perfect?
Well I'm looking for a sub for my Grand Cherokee. I'm making a custom enclosure in the side of the rear panel. I only want one sub and it will be powered by an older Rockford 800a2 amp. I still haven't decided if I want a 10" or a 12". Has anyone heard the Kappa Perfects?
Old Aug 30, 2005 | 07:52 PM
UofLeaderb18's Avatar
Default Re: Recommend me a sub: how's the Infinity Kappa Perfect? (JCDubya)
Its a nice sub. The Components are awesome, but the sub is lacking in my opinion. Sounds very tight and accurate if that's the sound you are looking for. Good Luck.
Old Aug 31, 2005 | 01:28 PM
JDubya's Avatar
Default Re: Recommend me a sub: how's the Infinity Kappa Perfect? (UofLeaderb18)
Well I'm not looking to shake house windows when I drive by. I just want some good, clean bass but that will hit hard when it needs to. I've never owned 10"s, just a bunch of 12"s. Can someone with 1st hand experience compare and contrast the two?
Old Aug 31, 2005 | 01:31 PM
tweekerz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCDubya &raquo;</TD></TR><TR><TD CLASS="quote">Well I'm looking for a sub for my Grand Cherokee. I'm making a custom enclosure in the side of the rear panel. I only want one sub and it will be powered by an older Rockford 800a2 amp. I still haven't decided if I want a 10" or a 12". Has anyone heard the Kappa Perfects?</TD></TR></TABLE>
DO NOT over power this sub. They are notorious for blowing with a hair of extra power. Do not port them, they only like sealed boxes.
Old Aug 31, 2005 | 01:38 PM
tweekerz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCDubya &raquo;</TD></TR><TR><TD CLASS="quote">Can someone with 1st hand experience compare and contrast the two?</TD></TR></TABLE>
do you want loud or louder? thats what it comes down to.
Old Aug 31, 2005 | 01:42 PM
JDubya's Avatar
Default Re: Recommend me a sub: how's the Infinity Kappa Perfect? (tweekerz)
So the bass sounds the same, the 12 is just louder? The only reason I'd get a 10" is b/c it takes up less room.
Would my Rockford amp be overkill for the Kappa Perfect?
What other subs would you recommend?
Old Aug 31, 2005 | 01:52 PM
tweekerz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCDubya &raquo;</TD></TR><TR><TD CLASS="quote">So the bass sounds the same, the 12 is just louder? The only reason I'd get a 10" is b/c it takes up less room.
What other subs would you recommend?</TD></TR></TABLE>
yeah thats a pretty beefy amp. 800x1@4ohms. way too much power. unless you run two kappa perfects 400x2 @ 2ohm dvc and keep the gains down.
I dont think the perfect is the right choice for your amp. Whats your budget for a sub? Are you looking for sound quality or all out spl or somewhere inbetween?
Old Aug 31, 2005 | 02:10 PM
JDubya's Avatar
I don't really have a budget set but I don't fell like paying $400 for one sub either. I'm more interested in sound quality but still want it to be able to hit hard if i turn it up.
Old Aug 31, 2005 | 02:12 PM
Ti3d in's Avatar
I'm just running 1 10" Kappa Perferct and I love it. Sounds clean, but packs some bass when you need it. Oh yeah, they're designed to work really well in small boxes too.
Old Aug 31, 2005 | 02:17 PM
tweekerz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCDubya &raquo;</TD></TR><TR><TD CLASS="quote">I don't really have a budget set but I don't fell like paying $400 for one sub either. I'm more interested in sound quality but still want it to be able to hit hard if i turn it up. </TD></TR></TABLE>
how much space in terms of cubic feet do you have to work with?
Old Aug 31, 2005 | 02:25 PM
tweekerz's Avatar
check out the re audio se. its an sql driver and will take the 800w like a champ. prollu run you about 200 bucks but its a quality driver. http://www.reaudio.com
Old Aug 31, 2005 | 02:28 PM
JDubya's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tweekerz &raquo;</TD></TR><TR><TD CLASS="quote">
how much space in terms of cubic feet do you have to work with?</TD></TR></TABLE>
The less the better. I haven't made the enclosure yet so I'm not sure. I'm going to mold it into the panel on the left:
(not my pic but you get the idea)
Old Aug 31, 2005 | 02:57 PM
tweekerz's Avatar
you can prolly get away with 1 cubic ft not including sub displacement. if you go with the RE SE, their tech support will calculate a perfect volume for the amount of power you are using.
Old Sep 1, 2005 | 10:05 PM
212audiodynamics's Avatar
Default Re: Recommend me a sub: how's the Infinity Kappa Perfect? (Ti3d in)
try to use 2-8" kicker comp vr's, those sub are loud..
Old Sep 1, 2005 | 11:23 PM
vw eater's Avatar
what about a 15 thats 800 watts
Old Sep 2, 2005 | 04:01 AM
JDubya's Avatar
Default Re: (vw eater)
I only want one sub, no larger than 12"s.
Old Sep 2, 2005 | 01:58 PM
spooncivic01's Avatar
Default Re: (JCDubya)
look into a alumapro alchemy 10 or 12 amazing sub will do great in a small enclosure, can be loud as hell and as clear as hell.
Old Sep 2, 2005 | 03:21 PM
epraion62's Avatar
Go with JL audio since you want it to be a space saver.
Old Sep 3, 2005 | 03:58 PM
Slain's Avatar
I also recommend an alumapro alchemy 10-12.
Old Sep 3, 2005 | 07:24 PM
STEV3-O's Avatar
Default Re: (Slain)
Re-audio is the ****, its the very first line of products i got at my shop. If u are looking into getting one, let me know, ill do my best to give u the best price PS. also their tech support is very friendly
Old Sep 3, 2005 | 07:47 PM
vw eater's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCDubya &raquo;</TD></TR><TR><TD CLASS="quote">I only want one sub, no larger than 12"s.</TD></TR></TABLE>`
i got 3 12's in my rex...
Old Sep 3, 2005 | 08:25 PM
HiRevn's Avatar
I have a 10" Kappa (not a Perfect) in my Integra and it sounds really good. It's in a box which I would say is about 1 square cubic foot big. I've never really heard a Kappa Perfect in action, but must say that the Kappa is a pretty decent sub. It's clean, but not very loud. (not that it can't be loud)
Old Sep 5, 2005 | 07:56 AM
drumking15's Avatar
i have 3 kappa perfect 10's in a sealed box power off a jbl 600.1 in 1.3ohms...they are tight and clean...and i love them to death....only recently did i yank them out in favor of a resivior for my air/water intercoolin system...bu they are great subs imho
Old Sep 10, 2005 | 05:38 PM
Guam_CiviC619's Avatar
I've got one powered by a JBL BP600.1 They aren't notorius for blowing, they are notorius for the voice coil seperating from the spider. Don't know if that manufacturing issue was ever addressed but I fixed mine with industrial strength epoxy and I haven't had a problem slamming for almost 3 years. As said before, it <u>is</u> a tight and accurate sub, I love it, although if I were to do it over again I'd probably go for the 12".
Old Sep 10, 2005 | 05:51 PM
drumking15's Avatar
Default Re: (Guam_CiviC619)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Guam_CiviC619 &raquo;</TD></TR><TR><TD CLASS="quote">
I've got one powered by a JBL BP600.1 They aren't notorius for blowing, they are notorius for the voice coil seperating from the spider. Don't know if that manufacturing issue was ever addressed but I fixed mine with industrial strength epoxy and I haven't had a problem slamming for almost 3 years. As said before, it <u>is</u> a tight and accurate sub, I love it, although if I were to do it over again I'd probably go for the 12".</TD></TR></TABLE>
wow you have 1...i have 3...all powered by the same amp...id love to see what it sounds like at 4ohms...much more controlled
