how do i pin ecu to make it vtec
were can i get the pins from ecu .i am so confused i think of gettin a jdm itr swap obd2 but i have a 94 ls obd1,my friend is telling me to keep it obd1 an tht i just need obd1 gsr fuel injectors,dist, and ecu but then idk how to wire from vtec selonoid,knock sensor, and oil pressure idk how to do the pin out ****. plzz help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94IntegraLs04 »</TD></TR><TR><TD CLASS="quote">were can i get the pins from ecu .i am so confused i think of gettin a jdm itr swap obd2 but i have a 94 ls obd1,my friend is telling me to keep it obd1 an tht i just need obd1 gsr fuel injectors,dist, and ecu but then idk how to wire from vtec selonoid,knock sensor, and oil pressure idk how to do the pin out ****. plzz help</TD></TR></TABLE>
He's right, keep it obd1. for vtec and the knock sensor, you're only talking about 4 wires. You can just run wires directly from the sensors to the ecu pinouts (which are in the FAQ's at the top of this forum).
XSSIVE
Dec 16, 2003 06:16 PM
