gsr del slow
Old Aug 30, 2005 | 04:50 PM
elitetuning's Avatar
Default gsr del slow
this is the set up i have currently in my 94 del sol si
b18c1
je-11.1
eagle-rods
b18c1
3 angle job
ctr cams
itr vavetrain
stock mani/throttle body
stock fuel/ignition/cooling/oil
what hp should i get out of this ive seen 180whp on the site
soon i will be adding a skunk2 mani/tb
ngk plugs/msd wires
b/m fuel reg/gauge
aem rail
just wanted some insight on what next hopefully if moneys right s2s2 cams and full valvetrain
Old Aug 30, 2005 | 05:09 PM
Default Re: gsr del slow (elitetuning)
does ne 1 have any info for me it will be greatly apprciated
Old Aug 30, 2005 | 05:13 PM
serturbo's Avatar
Fuel pump, maybe. A friend of mine had a 98 teg. He did an ls/vtec and found that his stock fuel pump was starving his engine. His fuel pressure actually went down as he revved his engine. I'm not sure if this was just an isolated incident, but I recommend changing out the fuel pump anytime someone does an engine swap or vtec conversion. Just a piece of mind thing for me. You should be willing to spend the money on a fuel pump since you're willing to spend the money on a fuel rail, which will do almost nothing for performance at the level you are currently at. The AEM fuel rail is just for the bling factor.
rth_1984
Aug 3, 2011 05:04 AM
sticest
May 5, 2009 08:21 PM
BLU CIVIC
Oct 29, 2008 07:47 PM
g0ldywang
Jul 27, 2004 10:40 AM
DXDOHCVTEC
Aug 30, 2003 03:56 AM
