ZC won't spark, HELP PLEASE
I have an 89 crx with a dohc zc. I have no spark at all. Ive been through 2 distributors 3 coils and a new battery. Rywire did the harness and i had to repin the ecu. I think i did it right, the ones i ahd to repin were cylinder position sensor, crank angle sensor and injectors. Any ideas why i have no spark. Oo and also i only have 3.4 volts comming out of the coil to the dizzy cap, is this normal? should i have 12? Its probably the CAS, CPS, or dizzy but i dunno maybe somethin else. Please Please any input will help
fuses maybe or a bad ground wire. take a mutlimeter and check to see if the coil is hot on both neg and postive thats all i can think of.
do you have voltage at the black and yellow wire at your dizzy? that will cause a no spark< if not you could have a possable bad ignition switch?? good luck
TNTNight
Jul 6, 2008 10:41 AM
