what thickness head gasket for a LsVTEC 11:1?
I have a stock b18b block with a GSR head and CTR cams. I currently have a LS head gasket, but am considering bumping the compression just a smidgen with a thinner head gasket. What thickness and where can I get them?
thanks so much!
thanks so much!
You're only running about 9.8:1 comp right now, so in order to get up to the desired 11:1 you want, you'd have to use a single layer head gasket which you can buy from Cometic I believe (just do a search). That would get you close to 10.2:1, then you'd have to remove .040 thou of material in total from the block/head (deck the block .020 thou and plane the head the same amount) I wouldn't remove more than .030 off of the head just as a rule of thumb for durability etc. Doing this will give you the 11:1 you're looking for. It's those stock LS pistons that are killing you comp wise. Changing them to something like the P73-A0 (USDM type R) pistons and running the stock headgasket will give you about 11.1:1.
b16t4turbo
15
Apr 2, 2006 08:37 PM
