Bent trailing arm or bent hub?
Old Aug 30, 2005 | 11:12 AM
unknown0001's Avatar
Default Bent trailing arm or bent hub?
Hey guys, I'm having a hellova time getting a passenger hub/trailing arm in good condition. I drove a few hours Sunday and Monday night to cut off a trailing arm/hub from a 4dr teg but today I tried to work on it and clean it up and all the bolts are rusted to ****. ******* Canada and rust
So this is what I will do, the recent hub/trailing arm I got I'm going to drill through all the bolts and just use the trailing arm.
Now I have access to an integra that went into a ditch on the passenger side and wheel is bent in like this //
Now after thinking about the way the metal would flex, the hub is made out of strong steel while the trailing arm is a pretty thin build. If the car went into the ditch do you guys think that the trailing arm just bent and/or would the hub be also bent?
I'm thinking the hub is ok since t's bolted onto the trailing arm good and the trailing arm would most likely bend but what do you guys think?
Old Aug 30, 2005 | 03:08 PM
Default Re: Bent trailing arm or bent hub? (Mr.RHTuner)
any ideas?
Old Aug 30, 2005 | 04:32 PM
nighttrain33's Avatar
Odds are, it is the trailing arm. If you can match it up to the other side to see how they look comparatively, it should help.
-Shane
TOO MUCH TORQUE
Northern California (Sales)
Jan 29, 2016 06:15 PM
prelude_93vtec
Jun 2, 2008 07:34 AM
92civicx
Oct 4, 2007 05:19 PM
slowassR
Aug 16, 2002 01:41 PM
slowassR
Aug 15, 2002 02:06 PM
