A/C Issue
Old Aug 30, 2005 | 11:05 AM
Jesterian's Avatar
Default A/C Issue
Alright, my AC finally died on me. I'm assuming the freon finally ran out. Unfortunately, it's still running the old freon. I've heard that to have it flushed and converted to the new freon could be over a hundred bucks. Also, I'm gonna be getting a full hmotorsonline swap sometime soon. Should I just wait for after the swap to get my A/C fixed?
Old Aug 30, 2005 | 11:43 AM
sam385's Avatar
Default Re: A/C Issue (Jesterian)
be sure to plug your lines after you disconnect the system
try not to convert to r-134a...it does not cool the same. i would wait to do the swap , then fix the a/c so you don't have to do it twice.
Old Aug 30, 2005 | 01:42 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: A/C Issue (sam385)
You don't have to discharge the a/c to replace the engine..
Just unbolt the compressor and wire it up out of the way..
Old Aug 30, 2005 | 08:35 PM
Jesterian's Avatar
Default Re: A/C Issue (88DXCRX)
I'll be replacing the compressor. The hmotors full swap comes with a new one. Also, where can I pick up the old style freon?
FuriousYellowSi
Honda Civic (2001 - 2005)
Oct 26, 2008 10:58 AM
bonestock92si
Jul 21, 2008 07:49 PM
dlg0187
Apr 22, 2008 05:14 PM
Hughie123
Oct 16, 2003 03:39 PM
