How can u tell if u have a SI or HF transmission?
Old Aug 30, 2005 | 09:01 AM
DsMWookie's Avatar
Default How can u tell if u have a SI or HF transmission?
I was looking at the code on my transmission and it says L-3 I thought that was an SI transmission.....Do i need to read the rest of the numbers or what?
Old Aug 30, 2005 | 09:09 AM
SSJSubgeta's Avatar
Default Re: How can u tell if u have a SI or HF transmission? (DsMWookie)
dude before anyone flames you, get your shield up.....
you can tell obiously if you have a CRX HF or SI model, thats for the not mech peeps,
also HF trannys are longgggggg-geared for that MPG economy. SI Trannys are short geared for more accel.
Im not an expert but do a SEARCH, look for info, read and cheers to knowledge!!!!!11!!!
Old Aug 30, 2005 | 09:21 AM
splitime's Avatar
Default Re: How can u tell if u have a SI or HF transmission? (SSJSubgeta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SSJSubgeta &raquo;</TD></TR><TR><TD CLASS="quote">dude before anyone flames you, get your shield up.....
Im not an expert but do a SEARCH, look for info, read and cheers to knowledge!!!!!11!!! </TD></TR></TABLE>
And what if the tranny has been swapped? or its outta the car with an unknown history? or its not installed to test out the gearing?
I'd agree... you aren't an 'expert'
I know the codes are in a few threads in the archives, you'll have to use the search to find them. I know I found them awhile back to check a couple trannies of mine also. The info was somewhat vague... but helpful still.
Old Aug 30, 2005 | 09:31 AM
davens's Avatar
It should be painfully obvious...
Put the car in 5th and go 80 mph...how many rpms are on the tach?
Old Aug 30, 2005 | 09:43 AM
djsire's Avatar
Default Re: (davens)
i think he means without it installed. but if it is installed do you get 50 miles per gallon?
Old Aug 30, 2005 | 09:57 AM
Jonathan_ED3's Avatar
How are you supposed to do that with the transmission out of the car?
Old Aug 30, 2005 | 10:03 AM
RaysBoomBoomLude's Avatar
Default Re: (Jonathan_ED3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonathan_ED3 &raquo;</TD></TR><TR><TD CLASS="quote">How are you supposed to do that with the transmission out of the car?</TD></TR></TABLE>
WTF, did you just not read?
Old Aug 30, 2005 | 10:05 AM
Tell me how to put my transmission in 1st gear with it sitting on the ground.
I'm quite ignorant....explain exactly how to do it.
Old Aug 30, 2005 | 10:07 AM
splitime's Avatar
Default Re: (LaFawnduh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LaFawnduh &raquo;</TD></TR><TR><TD CLASS="quote">WTF, did you just not read? </TD></TR></TABLE>
No need to be rude about it... its not everyone that will realize the above method requires you to crack the transmission open.
It would take decent tranny knowledge to crack it open, engage the first gear and go from there. IE: tranny disassembly, which and how to engage first gear using either the **** rod or the forks.
Old Aug 30, 2005 | 10:10 AM
Is there no solid method to use to determine type of transmission with it not in the car and without having to crack it open?
Old Aug 30, 2005 | 10:15 AM
Default Re: (splitime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime &raquo;</TD></TR><TR><TD CLASS="quote">No need to be rude about it... its not everyone that will realize the above method requires you to crack the transmission open.
It would take decent tranny knowledge to crack it open, engage the first gear and go from there. IE: tranny disassembly, which and how to engage first gear using either the **** rod or the forks.</TD></TR></TABLE>
Id you read above, all you have to do is put it in first. Just look at witch direction your shift rods go to put the transmission in first.
That above diagram, DOESNT require taking it apart.
That diff that its talking about is what you see when you take the axles out, Its clear to see.
Edit: Edit your response so when people search when they read your stuff they wont get the wrong info.
Old Aug 30, 2005 | 10:19 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
The method Tyson posted worked for me..
To put the transmission in first,Turn the shift input shaft
to the left and pull it out..
Make a reference mark on the case,
Then clamp a small pair of vice-grips on the input shaft and turn.
Old Aug 30, 2005 | 10:40 AM
EJ1 wilcox's Avatar
Default Re: (88DXCRX)
Wow!
Awesome information!
I am going to be looking for an Si tranny soon and it will be nice to test it before I spend my money based on some guy's word.
Thanks!
Old Aug 30, 2005 | 10:49 AM
splitime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX &raquo;</TD></TR><TR><TD CLASS="quote">The method Tyson posted worked for me..
Then clamp a small pair of vice-grips on the input shaft and turn.</TD></TR></TABLE>
And there is the missing link that avoids cracking tranny open. Now my format/thoughts can be avoided.
Old Aug 30, 2005 | 10:52 AM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonathan_ED3 &raquo;</TD></TR><TR><TD CLASS="quote">Tell me how to put my transmission in 1st gear with it sitting on the ground.
find neutral. push the shifter counter clock wise, and pull out. youre in first gear.
then use a vice grip on the end of the input shaft, turn clockwise and count 10 turns.
i really thought these pics were self explanatory.
Old Aug 30, 2005 | 12:05 PM
DsMWookie's Avatar
Default Re: (Tyson)
Ok for the first guy im not a moron ....the car is an HF but the transmission gears were REALLY short feeling. I am putting a ZC in the car and I want to know what kind of transmission it is before I put it back in. I was getting about 38mpg in city and it seemed to be running rough but the gears didn't feel like an HF's should (high rpm's in 5th). I was wondering if theirs any codes...being that I have the transmission bolted up to the motor I don't feel like taking it off again.
Old Aug 30, 2005 | 12:07 PM
Default Re: (DsMWookie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DsMWookie &raquo;</TD></TR><TR><TD CLASS="quote">Ok for the first guy im not a moron ....the car is an HF but the transmission gears were REALLY short feeling. I am putting a ZC in the car and I want to know what kind of transmission it is before I put it back in. I was getting about 38mpg in city and it seemed to be running rough but the gears didn't feel like an HF's should (high rpm's in 5th). I was wondering if theirs any codes...being that I have the transmission bolted up to the motor I don't feel like taking it off again. </TD></TR></TABLE>
what RPM is it turning at 80 mph in 5th? its very simple. high RPM's above 3K rpms its not an HF trans.
Old Aug 30, 2005 | 12:17 PM
EDIT: Figured it out
Old Aug 30, 2005 | 12:26 PM
I must not have it in first gear, because my reference point ends up nowhere near any of the indicated marks!
Old Aug 30, 2005 | 12:51 PM
Nerologic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">
Mista Bone archived's to the rescue
Old Aug 30, 2005 | 12:53 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonathan_ED3 &raquo;</TD></TR><TR><TD CLASS="quote">I must not have it in first gear, because my reference point ends up nowhere near any of the indicated marks!</TD></TR></TABLE>
what is the id of your tranny? L3?
Old Aug 30, 2005 | 01:11 PM
DsMWookie's Avatar
yah doing 80mph Im pretty sure the RPM's were above 3k I think they were near that around 60......Its been a cpl weeks since Ive driven it so I can't remember exactly. But with the HF motor and the mystery tranny im sure it was 3k+ at 80mph...does the motor change the RPM's-gear ratio?
Old Aug 30, 2005 | 01:13 PM
b16_madman's Avatar
This is his slow car and he's not a moron.
Old Aug 30, 2005 | 01:16 PM
Tyson's Avatar
http://crx.honda-perf.org/math/index.html
do the math yourself. its all independent of the engine.
Old Aug 30, 2005 | 02:03 PM
DsMWookie's Avatar
Default Re: (Tyson)
Super cool Tyson that will come in handy.....i def think it was an HF or dx transmission.
