where is the MES ( memory erase signal ) on a 4th gen prelude
For the 4th gen you can undo the 10 amp clock fuse and it will reset the ECU. I dunno about the SRS computer though.
Pirate
Pirate
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred »</TD></TR><TR><TD CLASS="quote">For the 4th gen you can undo the 10 amp clock fuse and it will reset the ECU. I dunno about the SRS computer though.
Pirate
if i unplug the battey cant that reset the ecu?
anyone know where the MES is at?
Pirate
from my prior experiences, pulling the battery does not reset the SRS light (well.. atleast in the time period I let the unit sit.. which was more than enough time to reset the ECU a hundred times lol).
My guess is if something's up with the SRS it's considered a major safety issue and they want to make sure you get it checked, and not just pull a fuse and the light goes away.
I know on the civic's it's to the left of the steering column.. atleast on the ~96-98. I dunno if that's where it's at on the 4th gen's or not
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjr162 »</TD></TR><TR><TD CLASS="quote">from my prior experiences, pulling the battery does not reset the SRS light (well.. atleast in the time period I let the unit sit.. which was more than enough time to reset the ECU a hundred times lol).
I know on the civic's it's to the left of the steering column.. atleast on the ~96-98. I dunno if that's where it's at on the 4th gen's or not</TD></TR></TABLE>
i know for sure its nothing wrong with the system because i stilled a JDM climate control and i started the car without the passenger plug in. then the light stayed on.
but anyways i fixed the problem. the dash plug was loses
and i pluged it back in and everything is working great.
