HF hubs/b16a swap
Old Aug 29, 2005 | 10:40 PM
EF8IGHT's Avatar
Default HF hubs/b16a swap
Hey,
i was wondering if ill need new hubs when i swap my b16a into my hf?
i searched and found nothing
thanks
Old Aug 29, 2005 | 11:51 PM
JohnnieChimpo's Avatar
Default Re: HF hubs/b16a swap (liviN L363ND)
HF uses smaller hubs in the spindles than pretty much anything else.
You will be swapping to Integra axles to run your B16 and Integra axles have a bigger spline than an HF or 4 speed civic. Unless there is some way to pull the Teg CV joint off and reuse the HF CV joint, you'll have to swap to any other 88-91 CRX or 4th gen Civic spindles. I used 90-93 Integra DA spindles. They fit fine and drove fine plus they had bigger brakes. Later I swapped to 90-91 Civic EX spindles and felt no difference.
Old Aug 30, 2005 | 01:58 PM
EF8IGHT's Avatar
Default Re: HF hubs/b16a swap (JohnnieChimpo)
thanks
4doorcivic16
Mar 19, 2007 06:39 PM
coot_er
May 21, 2004 09:24 AM
Skinnypunk
May 16, 2004 03:30 PM
Project_ED8
Oct 23, 2003 08:46 PM
CRX A4
Mar 3, 2003 07:50 PM
