1990 crx master cylinder ?
Hey there everyone, I'm a new Honda convert, for the time being as long as gas is at these prices. I need to replace my master cylinder and want to know if the master is the same for the crx as it is the civic. I have a 1990 crx HF with the 1.5L and am trying to find a new master and want to know if the master is the same for these two models. Anyone have any advice or info to share with me and where I might find one for cheap? Anyone trust Ebay for parts? Just wondering if someone can help. Thanks
Luke
Luke
Your best bet is to go to autozone or pepboys or something and buy piece from them. It's super easy to replace...you can upgrade (?) to the 15/16 master cylinder (90-93 integra) from the 13/16 unit that is in your car now (which is the same as the civic...atleast most of the models I believe). You'll be able to tell as they are stamped on the side. All you need to do is remove the two brake lines from the side of the unit, and the two bolts holding the master cylinder to the brake booster...install in reverse fashion and bleed as required.
Tommy_Gunns
Dec 7, 2002 09:49 PM
RAWbertCuBus
Oct 19, 2002 08:00 PM
