d16z6 and d16y8 crank the same??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alexsracing »</TD></TR><TR><TD CLASS="quote">does it affect the way the crank pully goes on the tab? example.
will I still be a able to use the marks on the pully for 16 base timing on a z6 , useing a y8 crank?</TD></TR></TABLE>
The cranks are the same. The keyway is still at zero degrees. Hell, the D17 crank that I use is still at zero. Don't worry. Size the bearings right, drop it in, and go.
Neutex22
Mar 22, 2005 12:42 PM
