seperating hub from trailing arm?
Hey guys I've read about this in the past but can't find the link. Does anybody know how many bolts and what kind socket I need to take off a hub from a trailing arm for a 94 civic?
thanks
thanks
I believe a 32mm nut, and 4 T50 Torx bolts if your refering to the spindle that holds the drum backing or hub/caliper mount to the trailing arm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline96LX »</TD></TR><TR><TD CLASS="quote">I believe a 32mm nut, and 4 T50 Torx bolts if your refering to the spindle that holds the drum backing or hub/caliper mount to the trailing arm.</TD></TR></TABLE>
Yes that's what i'm refering to.
T50 torx bolts...dam
Built B16A
May 26, 2006 11:58 AM
unknown0001
Aug 30, 2005 04:32 PM
