Tap Size for 14mm bolt from rear upper arm
Old Aug 29, 2005 | 07:11 PM
haveaniceday's Avatar
Default Tap Size for 14mm bolt from rear upper control arm
i need to know the tap size for the 14mm bolt for the rear upper arm .. i believe it is 11mmx1.50 but just making sure.. also can anyone give me tips or advice before i start to do this .. being first time and everything
Modified by haveaniceday at 2:49 PM 8/30/2005
Old Aug 29, 2005 | 08:20 PM
Default Re: Tap Size for 14mm bolt from rear upper arm (haveaniceday)
bump.. help ..
Old Aug 29, 2005 | 08:24 PM
EK k kay's Avatar
You mean rear upper control arm? I'm sure it's a 10x1.25 since that was what size bolts people told me to get when doing a rear camber fix.
Old Aug 30, 2005 | 01:49 PM
Default Re: Tap Size for 14mm bolt from rear upper arm (chowmien)
anyone else? any input
Old Aug 30, 2005 | 02:24 PM
RedlinedVTEC's Avatar
Chowmien is correct with 10mmx1.25mm.
Old Aug 30, 2005 | 07:36 PM
Default Re: Tap Size for 14mm bolt from rear upper arm (RedlinedVTEC)
any tips? just lube it up, take my time.. thats really it i think
swizz977
19
Jan 2, 2012 07:22 PM
fritter critter
Nov 21, 2009 05:37 PM
spankey167
Apr 12, 2005 05:36 AM
xkwzt21
Nov 10, 2004 03:42 PM
cappa
Oct 20, 2004 07:27 AM
