Do Valve springs really go bad?
Old Aug 29, 2005 | 05:50 PM
ThatsMyEG's Avatar
Default Do Valve springs really go bad?
i heard skunk2 springs get worn out after 30k miles is this true?
Old Aug 29, 2005 | 07:18 PM
therealpoorboy's Avatar
Default Re: Do Valve springs really go bad? (ThatsMyEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThatsMyEG &raquo;</TD></TR><TR><TD CLASS="quote">i heard skunk2 springs get worn out after 30k miles is this true? </TD></TR></TABLE>
yes valve springs wear out. but theres no real set time limit. depends on how they are used.
Old Aug 30, 2005 | 08:59 AM
Rocket's Avatar
Default Re: Do Valve springs really go bad? (therealpoorboy)
Depending upon how much heat they take for being worked up and down they will loose pressure.
Old Aug 30, 2005 | 01:06 PM
ThatsMyEG's Avatar
Default Re: Do Valve springs really go bad? (Rocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">Depending upon how much heat they take for being worked up and down they will loose pressure.</TD></TR></TABLE>
could it make a vavle slip and hit a piston or does it just make the valve stick open?
Old Aug 30, 2005 | 01:14 PM
Rocket's Avatar
On the exhaust it may not close the valve in time.
Not enough spring pressure will cauze the valve to bounce on the seat and this pounds out the valve job and looesen seats.
Old Aug 30, 2005 | 01:18 PM
ThatsMyEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">On the exhaust it may not close the valve in time.
Not enough spring pressure will cauze the valve to bounce on the seat and this pounds out the valve job and looesen seats. </TD></TR></TABLE>
loosin what seats? im just wonder if i put my old valve train that has about 20k miles on it will it eventually mess up my motor if they wear out? i just spent $2k on my bottum end thats why im asking. thanks for the help
Old Aug 30, 2005 | 01:25 PM
slofu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThatsMyEG &raquo;</TD></TR><TR><TD CLASS="quote">could it make a vavle slip and hit a piston or does it just make the valve stick open?</TD></TR></TABLE>
don't worry. if the valve sticks open or closes too slowly, the piston will close it.
Old Aug 30, 2005 | 01:26 PM
Rocket's Avatar
Vavle seats can go loose when you have enough valve bounce.
Springs are a life saver in perf. motors. Trackmasters use to build alot of high hp turbo motors. Alot of them would blow from overeving due to the turbo motors breaking tires loose etc and slamming into the rev limit. After they started using stiffer springs this pretty much cured that problem.
Old Aug 30, 2005 | 01:41 PM
ThatsMyEG's Avatar
Default Re: Do Valve springs really go bad? (slofu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slofu &raquo;</TD></TR><TR><TD CLASS="quote">
don't worry. if the valve sticks open or closes too slowly, the piston will close it. </TD></TR></TABLE> is that a joke?
Old Aug 30, 2005 | 02:02 PM
DonF's Avatar
Nascar teams replace the valve springs, after every event on $80,000 motors. That may give you a clue. Valve springs and retainers are consumables and should be replaced every rebuild or every time the motor is taken apart.
Old Aug 30, 2005 | 02:19 PM
ThatsMyEG's Avatar
Default Re: Do Valve springs really go bad? (DonF)
thats alotta cash, my friend but i tottally agree. i kinda wanted somebody to encourage me to change them.
anybody wanna buy some skunk2 valve springs and retainers. lol seriously
Old Aug 30, 2005 | 02:24 PM
ThatsMyEG's Avatar
Anybody know where i can get a good deal on some new ones?
Old Aug 30, 2005 | 02:34 PM
Anti-Drama Queens's Avatar
http://www.sparkracing.com , ask for jerry...he'll hook u up with some decent prices on supertech stuff
Old Aug 30, 2005 | 06:08 PM
onepoint6i's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThatsMyEG &raquo;</TD></TR><TR><TD CLASS="quote">Anybody know where i can get a good deal on some new ones? </TD></TR></TABLE>
go figure:
http://m24x.com/products.htm#
89si-rex
10
Nov 9, 2013 07:32 AM
SeDA(9)n
Nov 29, 2007 02:19 PM
DC4_MADMAN
Nov 14, 2006 06:24 AM
jdm ek9 101
11
Sep 4, 2006 06:04 PM
phrasathane
13
Mar 30, 2004 10:56 AM
