99 AT Trans Service
Old Aug 29, 2005 | 04:52 PM
QuietGiant's Avatar
Default 99 AT Trans Service
I have a 99 Accord 4cyl AT. I am servcing all the fluids ie: replacing them with fresh (51,000). Is there a trans filter screen? If not, should I just R&R the fluid through the filler or should I pull the pan and replace any screen that may exist. Your thoughts.
QuietGiant
Old Aug 29, 2005 | 11:30 PM
HondaTechPro's Avatar
Default Re: 99 AT Trans Service (P_Adams)
I don't want to sound like a dick.... but when you provide advice to people, it would be good if you knew what you were talking about. A 99 Accord does NOT have a transmission pan. It has a drain plug that goes right into the ALL ALUMINIUM CASE. There is no screen you can access or clean with out removing the transmission from the car and splitting the case open. Seriously... I know you own a Honda, but that doesn't make you an expert. As for the service... it's drain and fill. It will take about 2.5 qts.... use only Honda ATF. And as for the magnet idea... believe it or not, Honda actually thought about that. The drain plug has a big magnetic end on it.
Old Aug 30, 2005 | 03:58 AM
P_Adams's Avatar
Default Re: 99 AT Trans Service (HondaTechPro)
I'll note it in the book
I'm glad Honda agrees with me, but sad that they decided to make them throw-away transmissions (can't service them)
Modified by P_Adams at 2:16 PM 8/30/2005
Old Aug 30, 2005 | 08:51 PM
Stripped Honda's Avatar
99-0104
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaTechPro &raquo;</TD></TR><TR><TD CLASS="quote">I don't want to sound like a dick.... but when you provide advice to people, it would be good if you knew what you were talking about. A 99 Accord does NOT have a transmission pan. It has a drain plug that goes right into the ALL ALUMINUM CASE. There is no screen you can access or clean with out removing the transmission from the car and splitting the case open. Seriously... I know you own a Honda, but that doesn't make you an expert. As for the service... it's drain and fill. It will take about 2.5 qts.... use only Honda ATF. And as for the magnet idea... believe it or not, Honda actually thought about that. The drain plug has a big magnetic end on it.</TD></TR></TABLE>
guess what you sounded like a dick ..... this guy is asking a question to learn there is no reason you have to reply like this ... just explain the answer to his problem and the problem will be solved .... in this case this guy is a new member and a reply like that only scares off the new users and makes them think that we are unfriendly here and that is not the case ..... remember this is the accord forum the people that come here usually know little to very little about cars and most would like to learn about them ...
Old Aug 31, 2005 | 08:37 AM
Default Re: 99 AT Trans Service (Stripped Honda)
i agree that my answer was more corse than it needed to be. However it wasn't directed at the person asking the question. I get irritated by all the bench racing and "implied knowledge" that is present on this board. The following statements are NOT directed at anyone in particular... If you are not sure about something ask someone that knows... If you don't know, don't guess... Don't rely on sport compact car mags for all of your automotive knowledge, just because you own a civic or an integra and somehow hacked in a different motor, you're not an expert. PLEASE ANSWER PEOPLE'S QUESTIONS, BUT MAKE SURE YOU ARE CORRECT IN THE INFORMATION YOU PROVIDE!!!!!! There's nothing worse than giving someone who knows only a little baout cars the wrong info. If you get together 100 people that each know a little bit about cars, that doesn't make then collectively an expert. Rant over.
Old Aug 31, 2005 | 09:24 AM
YeuEmMaiMai's Avatar
Default Re: 99 AT Trans Service (QuietGiant)
DO A DRAIN AND FILL. or (against the recommendations of Honda) you can do a flush with a wynns machine. I did a flush on my car at 90K because the previous owner did not have any recods after 30K for trans service.
Old Aug 31, 2005 | 09:35 AM
esmote's Avatar
I have a 1993 Accord. Is it the same way, no filter just a drain plug. I just bought the car last week and haven't had time to crawl under it yet.
Old Aug 31, 2005 | 02:41 PM
SuNDaY DRiVeR's Avatar
dude.. seriously.. u need to get laid n chill out a bit
Old Aug 31, 2005 | 03:24 PM
deserthonda's Avatar
yo Honda,,,,,, i hear what u r saying and to be honest sometimes i shake my head in disbelief at some of the advises i read people give , but in their way they are trying to help , you and a few others might have a bit more experience so we know that it is totally way off the wall but to their credit they also believe that the answer they are giving is the right one and only trying to be helpful.....
just do not let it get under your skin . all u can do is be friendly and give your opinion ( advise) and it is up to the individual which 1 to take ,,eventually the right answer will surface and giving enough help and right answers the people here wil come to respect you and your ability ..........
Old Sep 2, 2005 | 09:13 AM
QuietGiant's Avatar
I appreciate the active effort to assist me in my basic of questions.
It may be my inability to comprehend but, please confirm the answer.
Am I correct that the answer is: Drain from the plug & Fill with Honda trans fluid. No pan nor screen to service. Correct?
Old Sep 2, 2005 | 09:29 AM
QuietGiant's Avatar
Also, is it necessary to use HONDA Transmission Fluid. Can't I use a high quality national brand. Is it THAT different? Thanks for your continued patience with me. QuietGiant
Old Sep 2, 2005 | 10:39 AM
amckee's Avatar
Default Re: (QuietGiant)
I am also curious what the factory tech thinks about this. I know that you can't buy as good a trans fluid from an auto parts store as what comes from the factory( ford & GM that is).
Old Sep 2, 2005 | 02:35 PM
Default Re: (amckee)
This is the exact wording from the May '95 servicenews:
We have nothing against other major brand manufacturs... but their ATF wasn't designed specifically for the Honda transmissions... Ours was.
Honda ATF is different than others. Other brands will work, but shift quality will be worse. Just buy the Honda fluid... it isn't that costly.
As for the procedure.... drain from the plug, refill. It will take between 2.5 and 3 qts.
Mikerob
Dec 25, 2018 04:48 PM
F23vtec
Mar 22, 2016 06:51 PM
cueto
10
Jul 20, 2012 05:26 PM
Damnedrider
Aug 15, 2011 08:10 AM
gmin
May 14, 2011 07:05 PM
