New Vids of my Holset boosted CRX
Here's a pic of what car is in the vids
same old deal, right click save as
Here is a normal run:
http://copperpenney.com/crxsite/tmp/run1.avi
My GF pulling away:
http://copperpenney.com/crxsit...y.avi
Burnout:
http://copperpenney.com/crxsite/tmp/burnout.avi
In car vid:
http://copperpenney.com/crxsite/tmp/inCar.avi
more will come later
EDIT: New vids
Silencer removed in both of these:
http://www.copperpenney.com/cr...r.avi
another run:
http://www.copperpenney.com/crxsite/tmp/run2.avi
some specs are stock b16 with Holset HY35 running 10psi with a fake greddy typeS bov and fake tial wastegate with 2.5" dp and 2.25 exhaust, all good for 268.8whp
Modified by model x at 1:46 AM 8/30/2005
Modified by model x at 11:36 PM 8/30/2005
My GF pulling away:
Burnout:
In car vid:
EDIT: New vids
another run:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by model x »</TD></TR><TR><TD CLASS="quote">any suggestions?</TD></TR></TABLE>
Yeah, 3 inch exhaust and DP! It Sounds good man, hows it pull?
Guest
Posts: n/a
Are you running a first gen or a second gen B16A? Even if you are running the first gen, 10.2:1 compression and 10psi with stock internals is ballsy. Sounds good as hell though
You might look into finding a thicker than stock headgasket to lower compression.
Edit: Looked at one of your pics and the PGM FI on the intake manifold shows that you are indeed running a first gen B16A.
You might look into finding a thicker than stock headgasket to lower compression.Edit: Looked at one of your pics and the PGM FI on the intake manifold shows that you are indeed running a first gen B16A.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kNOwLedGeDA9 »</TD></TR><TR><TD CLASS="quote">Are you running a first gen or a second gen B16A? Even if you are running the first gen, 10.2:1 compression and 10psi with stock internals is ballsy. Sounds good as hell though
Edit: Looked at one of your pics and the PGM FI on the intake manifold shows that you are indeed running a first gen B16A.</TD></TR></TABLE>
second gen would be even worse and there's lots of people making more power on stock internals. You can't just say 10psi is to much; 10psi is different from turbo to turbo based on size.
Anyway I'm not too worried but thanks for caring
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM »</TD></TR><TR><TD CLASS="quote">learn to shift thats my only suggestion .car looks and sounds great.</TD></TR></TABLE>
why do you think I need to learn how to shift?
You might look into finding a thicker than stock headgasket to lower compression.Edit: Looked at one of your pics and the PGM FI on the intake manifold shows that you are indeed running a first gen B16A.</TD></TR></TABLE>
