possible to mig on a dsm side mount intercooler
Old Aug 29, 2005 | 04:19 PM
Stewie's Avatar
Default possible to mig on a dsm side mount intercooler
I don't know **** about welding so I was hoping some of you experienced guys can help me out. I'm putting together a turbo kit for my integra and I wanted to use a dsm side mount intercooler seeing as how easy they are to come by.
The thing is, the outlets aren't facing the correct way to be used as a front mount on my teg. But I was thinking, I would easily be able to fix that if it was possible to mig on the intercooler. I think it's made out of aluminum.
Here's a pic of the IC I'm talking about
Old Aug 29, 2005 | 10:31 PM
g2lsvtec's Avatar
Default Re: possible to mig on a dsm side mount intercooler (Stewie)
they make alum migs, but if u dont have one than u cant just use a norm mig, there alot diff, norm people tig weld alum because its easyer, nicer looking and holds better, better penatration, just go to a machine or welding shop and get them to weld up pipes coming off where u want, and patch the old spots, or just get a fmic and spend a little more money
Old Aug 30, 2005 | 01:59 AM
cua0's Avatar
Default Re: possible to mig on a dsm side mount intercooler (g2lsvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2lsvtec &raquo;</TD></TR><TR><TD CLASS="quote">they make alum migs, but if u dont have one than u cant just use a norm mig, there alot diff, norm people tig weld alum because its easyer, nicer looking and holds better, better penatration, just go to a machine or welding shop and get them to weld up pipes coming off where u want, and patch the old spots, or just get a fmic and spend a little more money </TD></TR></TABLE>
you absolutely can use a normal mig for aluminum. it is recommended that you use a spool gun or a push-pull type setup though, it is possible to use a push type setup, just be very careful that you don't have any kinks or loops in your whip. you will also need to use 100% argon or an argon/helium mixture instead of argon/co2 mig mix.
be sure to clean the area to be welded very well using alcohol and preheat it as well and you should have a pretty decent looking weld.
Old Aug 30, 2005 | 08:31 AM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2lsvtec &raquo;</TD></TR><TR><TD CLASS="quote"> norm people tig weld alum because its easyer, nicer looking and holds better, better penatration, just go to a machine or welding shop and get them to weld up pipes coming off where u want, and patch the old spots, or just get a fmic and spend a little more money </TD></TR></TABLE>
Wrong, and you can get some nice welds out of a spool gun
Old Aug 30, 2005 | 12:37 PM
Stewie's Avatar
Default Re: possible to mig on a dsm side mount intercooler (90blackcrx)
thanks for your help to everyone who responded
meanB6teen
May 8, 2005 11:41 AM
civcexcoupeblack
Sep 26, 2003 10:24 AM
88crxvtec
Apr 8, 2003 08:41 AM
ZCHF
Mar 2, 2003 01:26 PM
B20LS-T
Jun 12, 2002 03:31 PM
