Jdm B16 with p61
Old Aug 29, 2005 | 04:16 PM
BoostinEJ1's Avatar
Default Jdm B16 with p61
I just found out today that my Jdm B16 has a P61(92-93 GS-R ECU, rare so I'm told) and not the ECU that it should be (either a P30 or PR3...). Is this hurting it in any way, is it better? I'd imagine whatever ECU is for the Jdm B16 would be best. My cross over is at 5700rpm's right now and it seems a little too high... Any help would be great thanks.
Modified by slowsinglecam at 8:36 PM 8/29/2005
Old Aug 29, 2005 | 04:18 PM
Luserkid's Avatar
Default Re: Jdm B16 with p61 (slowsinglecam)
Never heard of a p61. And isnt 92-93 OBD0?
BoostinEJ1's Avatar
Default Re: Jdm B16 with p61 (Luserkid)
I'm told it is OBDI, and I searched P61 and got 92-93 GS-R ECU's all day long...
Old Aug 29, 2005 | 04:36 PM
BoostinEJ1's Avatar
theres a picture
Old Aug 29, 2005 | 08:18 PM
BoostinEJ1's Avatar
hmm, no one...
Old Aug 29, 2005 | 08:22 PM
craiger's Avatar
Default Re: (slowsinglecam)
i got one on my b18c with hondata its "rare" i guess because 92-93 integra gsr only came with it its the same as a p30 just used on a b17a1
Old Aug 29, 2005 | 08:26 PM
BoostinEJ1's Avatar
Default Re: (craiger)
hmm then i suppose theres no reason to get rid of it... i dont know how different the maps are and all but i know that vtec cross over is a bit higher and the speed limiter or whatever is much higher as well.
Old Aug 29, 2005 | 08:50 PM
damnraz's Avatar
I wouldn't worry about using the p61 ecu for your b16 application, I don't know the maps very well but I can tell you this, the IM/TB from the 92-93 GSR is basically the same as the pr3, no dual stage butterflies, other than that.. the engine should run fine with it but if you want to retain the stock maps, grab yourself a p28 and let somebody burn you the p30 bin for your motor.
also the vtec engagment on the p30 is roughly 5700 also, since b16's are known for their top end power, 5700 is just about right, 8200 redline.
Old Aug 29, 2005 | 08:59 PM
BoostinEJ1's Avatar
i guess ill leave it in for the time being then.
Old Aug 30, 2005 | 02:23 AM
BoostinEJ1's Avatar
Old Aug 30, 2005 | 04:34 AM
siregcivic's Avatar
might as well just use the p61... if u get the jdm p30.. vtec at 5700.. rev at 8200 speed governer from 120-130.. i dont know why its different but it is...
just use urs.. it should be fine.. if you want more power.. u can use a p28 out of a 92-95 ex/si hatch and have it tuned that would help
Old Aug 30, 2005 | 06:04 AM
JDMlyfestyle's Avatar
Yes that is from a 93 GSR. that ecu will be fine on your motor. No major differences cept for Vtec engagement. the ignition maps are almost identical to the ITR maps which will not hurt your motor. just be sure your timing is dead on at 16 degree's
Old Aug 30, 2005 | 01:25 PM
BoostinEJ1's Avatar
Default Re: (JDMlyfestyle)
thanks
BoostinEJ1
Aug 29, 2005 05:35 PM
VRD^sam
Apr 11, 2005 10:45 AM
dropd4door
Aug 16, 2004 12:09 PM
