HELP need a wiring diagram please
HELP does anyone know a site i can get a JDM wiring diagram for a B18c???
is the wiring for a USDM b18c the same as a JDM b18c???
thanks
thanks
is your car orignally from Japan and right hand drive ? if no, then, NO you don't need Japanese wiring schematics for your car. You need use wiring schematics.
As far as the pinouts go they're the same, US or JDM.
like badCRX said......obd1 or obd2?
what year is your car and engine?
[Modified by Katman, 1:56 PM 2/25/2002]
i'm from new zealand and all our cars come from JAPAN
i'm not sure what year the b18c is out of i think its 1995 not to sure
i think its OBD1, the ECU is a P72 and it looks like this
its OBD1 isn't it????
thanks Guys for ya help
Hello Elmo,
Yea, that definitely looks like OBD1 ecu. Try this http://hondata.com/techwiringgsr.html
o' sorry -- yah its an OBD1 ECU alrighty.
here's a wiring diagram I made up, it should work on your car JDM or US sir..
Katman , correct me if i am wrong !
a JDM b18c going into a JDM civic would have the same wiring schematics as a USDM b18c going into a USDM civic ?
All wiring just plugs in the same ?
i need to wire the vtec pressure switch, vtec solenoid (green wire coming off seloniod right???), evap purge soleniod, and evap purge power.. i already know where the knock sensor is and have that wired, and im using a skunk2 IM so i dont need the sec butterfly.. do i even need to run the wires for the EVAP purge since im not using the sec butterflys??? thanks for the help..
Katman that diagram helped me out alot, im also looking for the same information.. i know where to put the ecu pin-outs in the harness but not sure what the wires are under the hood.. can you help out on that??
no you don't need to run wires for the evap solenoid crap thing at all.
