Injector cleanng setup?
Old Aug 29, 2005 | 12:49 PM
Tyson's Avatar
Default Injector cleanng setup?
im wondering what it would take hardware wise to make an injector cleaning setup.
obviously a fuel pump, injector manifold.
but what wiring stuff is needed? i think i would want it to be able to run continuously, look at spray pattern and mass fuel flow.
Old Aug 29, 2005 | 04:40 PM
vtecn8ive's Avatar
Default Re: Injector cleanng setup? (Tyson)
perhaps an enclosed area like a sanding booth. So its not spraying all over.
-Shane
Old Aug 29, 2005 | 04:54 PM
Tyson's Avatar
Default Re: Injector cleanng setup? (vtecn8ive)
well, id just spray each into a clear tube. thats not a problem. i just want to know how to wire it up.
Old Sep 10, 2005 | 02:29 PM
WitchHunter's Avatar
It takes the following things to get any meaningful results:
Pump
Regulator (preferably adjustable)
Guage (to measure the pressure)
Fuel rail (or a way to connect fuel to the injectors)
Test fluid (never use gasoline...very dangerous)
Current limiting resistors ( especially for the low Z injectors)
Way to pulse test the injectors (only doing a static test tells very little about the injector operation)
A way to accurately time the test.
Graduated cylinders (to measure the output)
Depending on what you are trying to achieve, this will get you close if you are careful.
Maybe a better bet is to send them to an injector shop and get them cleaned and tested. Our shop services them for $15 each, and supplies before & after test data.
If you do test them, be careful as any flammable fluid you use can be dangerous.
Gordon
WitchHunter Performance / InjectorServices
http://www.witchhunter.com
http://www.injectorservices.com
Fuel Injector Cleaning & Flow testing Service
Old Sep 10, 2005 | 02:36 PM
Tyson's Avatar
Default Re: Injector cleanng setup? (WitchHunter)
wow. thanks for the tips.
can you describe more on how to accomplish this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Way to pulse test the injectors (only doing a static test tells very little about the injector operation)
also, what kind of fluid? i figured gasoline would be bad...
youre price for injector cleaning is quite reasonable. RC engineering is just a few miles away, but they charge $25/.
Jjb122
Dec 22, 2016 03:15 PM
dayl
21
Apr 13, 2010 08:06 PM
SwappedTURBOegg
Aug 30, 2007 08:23 PM
TRuST
Mar 22, 2002 11:10 AM
