Homemade Cold Air / Short-Ram Intake from Scrap Parts
Old Aug 29, 2005 | 12:00 PM
d176g4dr's Avatar
Default Homemade Cold Air / Short-Ram Intake from Scrap Parts
I thought I'd throw this up for my first post here. This is my second upgrade on my 99 Civic EX 4dr. It's a homemade intake I put together over the weekend. I've read about all the intakes on the market and to be quite honest wasn't impressed, and I had an HKS Super-Mega on my 90 CRX SiR when I was in Okinawa back in '98 and loved it - except it sucked in dust.
..long story short, I used a K&N Style Filter-Head $25, HKS 3" Elbow cut 1/2" short and polished (had on hand), and a B18A 90 Integra Intake Factory Flexpipe $2. I also used a Subaru V-6 Hose Clamp to replace the TB Clamp - Honda's Hose Clamps are horrible - always corrode and strip out.
I relocated the IAT to the far-side and made a provision for the PCV Line and made a new line for the Valve Cover Line (not sure if this is a vent line or not). You can see this upclose in one of the pictures.
I'm kinda new to this, so anyone with any suggestions as to what lines are needed and what's not, let me know. And if you know what they do - I've haven't gotten ahold of a factory manual yet to figure the motor out yet.
This is a prototype, I just cut the board today and installed, and it's real rough, but I am going to find some thick plastic that doesn't crack, maybe a plastic fiberboard or something, and once I get the hoodline cut correctly, I'll be making the final box and adding the rubbing stripping and blocking off the openings around the box. I still have to make a partition off the front bumper to the radiator and scoop air to the inside behind the passenger front corner of the bumper for the intakes cold air source - should be slightly pressurized and have no radiator heat then.
Here's the pics.
Old Aug 29, 2005 | 12:18 PM
SkoundrelUSA's Avatar
cute little bastard
Default Re: Homemade Cold Air / Short-Ram Intake from Scrap Parts (d176g4dr)
Good idea but that sheet of wood is hilarious lol
Old Aug 29, 2005 | 12:27 PM
undertheradar's Avatar
Default Re: Homemade Cold Air / Short-Ram Intake from Scrap Parts (SkoundrelUSA)
Not bad, but you'd be better off making that baffle out of a sheet of aluminum.
Old Aug 29, 2005 | 12:28 PM
Mooneyes13's Avatar
nice concept, but that wood is ****** ghetto
Old Aug 29, 2005 | 12:33 PM
litterbox's Avatar
I am a (Trial User) Army
Default Re: Homemade Cold Air / Short-Ram Intake from Scrap Parts (Mooneyes13)
Good stuff. If you make a platic piece that'll replace that wood, maybe you could make a top part for it, kinda like a roof for a cleaner look.
Ingenuity.
Old Aug 29, 2005 | 12:35 PM
d176g4dr's Avatar
I agree, but I had to make a mockup outta something. I tried acrylic but it cracked too easily, and a shimming material that was decently thick, but kept getting sharp shards of steel, hands are torn up. So after looking for any other material in local stores (not many) I jsut gave up and pulled some wood sheets down from the attic.
I'd like to do this in alluminum once I figure out the exact sizing, but I got a feeling it's gonna be expensive for 1/8" or 3/16" sheeting - but it should be alot easier to cut.
Old Aug 29, 2005 | 12:38 PM
litterbox's Avatar
What was the primary purpose for using the wood? A brace or heat shield?
d176g4dr's Avatar
I'd honestly like to make it seal to the hood with rubber stripping. But your probably right, and it's alot of work sealing to that hood - ribbing is uneven at the areas of contact. Right now it's within 1/2" at the most from sealing - I took a mixture of flour and water in a ziplock gallon bag, layed it on the wooden partitions, and cut the partitions down to where they no-longer kept the hood from closing - took some time.
Old Aug 29, 2005 | 12:40 PM
litterbox's Avatar
Default Re: Homemade Cold Air / Short-Ram Intake from Scrap Parts (litterbox)
Did you notice a change in sound?
Old Aug 29, 2005 | 12:41 PM
d176g4dr's Avatar
Just a heat shield. There's a 90-degree Metal Brace for the HKS Eblow just at the intersection of the two partitions. The wooden partitions are just functional as, well, a partition - to restrict the hot air from the engine bay from entering the area where the intake filter head resides.
Old Aug 29, 2005 | 12:45 PM
d176g4dr's Avatar
Well it kinda got a little more hushed, but i felt a pickup in my midrange, and probably would have had some top-end too, if it weren't for my stock exhaust manifold and factory replacement exhaust (just bought this civic 3 weeks ago).
It was honestly a bit louder without the partitions, but I did notice it sounds more throatier - I can hear more of the valve actuation, sounds pretty badass though for a D16, I've only heard B-series sound this good.
I'd recommend a short-ram upgrade to anyone that owns a 6g, this has gotta be the best upgrade for making power right off the bat.
Old Aug 29, 2005 | 01:13 PM
VWVORTEX's Avatar
lol.. hey whatever.. shrug
Old Aug 29, 2005 | 01:53 PM
Phoenix Fire's Avatar
Interesting.........keep up posted on what happens?
siblueg's Avatar
Default Re: Homemade Cold Air / Short-Ram Intake from Scrap Parts (GripStar)
better treat the wood or you will have termites
Old Aug 29, 2005 | 01:58 PM
cxSHOE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">Good idea but that sheet of wood is hilarious lol</TD></TR></TABLE>
nah i think the pieces of paper to complete the seal is funnier...
Old Aug 29, 2005 | 02:55 PM
vsmhatched's Avatar
i don't know about that wood peice there, but i do have to say nice vavle cover thats completely smooth
Old Aug 29, 2005 | 03:00 PM
b 1 6 a 2's Avatar
Now, use that wood as a template and use colored or clear acrylic as your heatshield. The piece of wood is
Old Aug 29, 2005 | 03:15 PM
chinese acrobat's Avatar
Good to see people tryin things.
Old Aug 29, 2005 | 03:36 PM
EJ6_Hatch's Avatar
Default Re: (chinese acrobat)
Try Lexan next time... it doesnt shatter as easily as acrylic.
Old Aug 29, 2005 | 03:45 PM
davenavarro1's Avatar
wood? watch that thing set on fire. make atleast an aluminum bracket or something
Old Aug 29, 2005 | 04:06 PM
DAmn's Avatar
Default Re: (davenavarro1)
its a good concept, now make a duct for air to get up thru the fenderwell
Old Aug 29, 2005 | 04:11 PM
ekcivic9's Avatar
is the honda on his valve cover ground off?
Old Aug 29, 2005 | 04:14 PM
SupraCivic's Avatar
Default Re: (DAmn)
In my 97, my short ram sits about where yours sits right now, dont cai's usually sit lower?
Old Aug 29, 2005 | 04:19 PM
kaoss_11's Avatar
B A N N E D
ghetto garage racing
Old Aug 29, 2005 | 04:31 PM
rino924's Avatar
White Trash Wish Cash
Community Builder
Community Influencer
yeah, just like everyone else said, its ghetto as ****. Not a bad idea though, just use sheet metal.
