searching for NOS GSR plate instructions
I fully understand how to install the plate. I am looking for a jetting chart.
Also, do you guys remove the OEM plate or stack the NOS plate in there with the OEM one?
you have to run it with the oem plate in place.you just stack the nitrous plate on top of the oem one and buy some long bolts to hold it in place cus the stock bolts are too short
This is what I found.
It is from NOS/Holley's site.
It is the instruction manual.
http://www.holley.com/data/Pro...2.pdf
As soon as I have a WOT switch I am installing mine.
The only other question I have is,
The instructions say not to turn it on below 3000RPM but the sparybar is in the secondary runners. The secondary runners aren't open till ~5600RPM. I would think that it would work better with the IABs open. I'm sure it will add power no matter when it is turned on, I think though that I will only activate mine after 5600.
