PWO or PR3? im getting a new ecu...
Old Aug 29, 2005 | 11:41 AM
FakeJDMEF8's Avatar
Default PWO or PR3? im getting a new ecu...
so im replacing my engine for a new one...and i have the shoice between the two..my car is a 90 CRX Si and just wondering which one is better and what is the difference...
thanks
Old Aug 29, 2005 | 11:48 AM
vegaskurt's Avatar
Default Re: PWO or PR3? im getting a new ecu... (FakeJDMEF8)
what engine do you have?
Old Aug 29, 2005 | 11:51 AM
Jeff's Avatar
Banned
I just sold my parts car for 200$ with a chipped PWO ECU + Mini-Me setup lol.
Old Aug 29, 2005 | 03:00 PM
FakeJDMEF8's Avatar
first gen b16a jdm...
Old Aug 29, 2005 | 03:02 PM
insomniac791's Avatar
I think there are more programs avail. for the pr3.
Matt
Old Aug 29, 2005 | 04:46 PM
smutmonger's Avatar
im using the pr3.. until kyle from wired speed lab sends me the aem unit i paid for months ago. ( i hope he dies)
but anyway im very happy with my pr3
Old Aug 30, 2005 | 05:22 AM
FakeJDMEF8's Avatar
whars better about it?
Old Aug 30, 2005 | 05:35 AM
spcrxracer's Avatar
Default Re: (FakeJDMEF8)
get a z-dyne programmed ECU i have one and i love it! once the car is warmed up no rev limit, no speed limit and it runs the car like a champ. TOTALLY WORTH IT! http://www.zdyne.com/
Old Aug 30, 2005 | 05:53 AM
b16a2rex's Avatar
i have a z-dyne in my car and i havent been totally satisfied with it, it seems like i lost a little bit of power with it over the stock ecu
Old Aug 31, 2005 | 05:20 AM
spcrxracer's Avatar
Default Re: (spcrxracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spcrxracer &raquo;</TD></TR><TR><TD CLASS="quote">get a z-dyne programmed ECU i have one and i love it! once the car is warmed up no rev limit, no speed limit and it runs the car like a champ. TOTALLY WORTH IT! http://www.zdyne.com/ </TD></TR></TABLE>
Forgot to mention i also have a VAFC
I still like the Zdyne ECU tho
Old Sep 1, 2005 | 07:39 AM
FakeJDMEF8's Avatar
i have a chipped something OBD0 ecu in there now...should i just put the stock PR3 in there for reliability or does it matter. also can i just swap them in and out whenever or will that mess things up?
Old Sep 1, 2005 | 10:03 AM
Malgerus's Avatar
Too much $.
Get a PR3 or a PW0 (I've run both) and have it chipped. Buy a Willems burner and do your own tuning with Turboedit. Have launch control, any rev limit, vtec engagement, etc etc for much much cheaper than zdyne.
Old Sep 1, 2005 | 11:43 AM
cmyrex's Avatar
Default Re: (Mr. S)
i would runt the pr3 over the pwo the pr3 is more aggressive fuel mapping
Old Sep 1, 2005 | 11:54 AM
Malgerus's Avatar
Default Re: (cmyrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmyrex &raquo;</TD></TR><TR><TD CLASS="quote">i would runt the pr3 over the pwo the pr3 is more aggressive fuel mapping</TD></TR></TABLE>
Oh? They are pretty much the same. I didn't see any difference between the two.
Old Sep 1, 2005 | 12:37 PM
rice_classic's Avatar
Default Re: (Mr. S)
The PR3 also has a higher redline and I believe* that most of them were designed for the Manual transmission cars whereas the PW0's were for automatics... I think I'm wrong and am hoping to be corrected... but I KNOW that the fuel cutoff on the pr3 is higher.
I have a OBD0 pr3 just sitting around.
Old Sep 1, 2005 | 03:12 PM
FakeJDMEF8's Avatar
any other important info?
Old Sep 1, 2005 | 03:41 PM
cmyrex's Avatar
if both are available for same price just go for the pr3
Old Sep 1, 2005 | 04:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmyrex &raquo;</TD></TR><TR><TD CLASS="quote">if both are available for same price just go for the pr3 </TD></TR></TABLE>
they won't be. the PR3 is a far superior ecu for your application.. you WON'T find it for the same price as the PW0.
PW0's can be found for 50$ whereas PR3's start at 125$ and go for up to 200$.
Old Sep 1, 2005 | 05:04 PM
FakeJDMEF8's Avatar
cool...well im getting it with my smap..the pr3...any other input?
Old Sep 2, 2005 | 12:10 AM
Malgerus's Avatar
Default Re: (rice_classic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rice_classic &raquo;</TD></TR><TR><TD CLASS="quote">The PR3 also has a higher redline and I believe* that most of them were designed for the Manual transmission cars whereas the PW0's were for automatics... I think I'm wrong and am hoping to be corrected... but I KNOW that the fuel cutoff on the pr3 is higher.
I have a OBD0 pr3 just sitting around.</TD></TR></TABLE>
PW0 came in the JDM CRX SiR, and were M/T for the most part. I have never heard of an A/T PW0, though I don't doubt that there may be a few floating around.
Fuel and timing between PR3/PW0 is the same AFAIK, but you're right about the redline; My PW0 seemed to cut out around 8k, while the PR3 went to 8200. A simple chip can fix that though I had mine chipped and readily tunable for well under 100 dollars, and that fixed it. I also think the PR3 had a slightly higher VTEC engagement too.
Old Sep 2, 2005 | 12:14 AM
socalef9's Avatar
you fogot to mentionthat the pr3 vtec point is a 4800 instead of 5000. pr3 is much better than pw0 but ive noticed a lot of cars with pr3's run a litle rich (including mine)
Old Sep 2, 2005 | 12:27 AM
Malgerus's Avatar
Default Re: (socalef9)
Actually the PR3 seemed closer to 5k, and the PW0 seemed more like it was at 4800. And no the PR3 isn't "much" better, it's slightly better at best. And a quick edit with BRE will take away any advantage that the PR3 would have. So really the best thing to do is to get a PW0 and chip it, like I did.
Old Sep 2, 2005 | 10:35 AM
socalef9's Avatar
my friend has a pwo and i have a pr3. i know vtec hits a 4800, ive done research. if you just gonna chip it, go for the pr3 anyway, there are more programs for the pr3, i know caus ive been looking into chipping it for a while.
Old Sep 2, 2005 | 10:44 AM
EFSiR's Avatar
SAVE your money. Get it right the first time and forget about upgrading down the road.... and all the bs with the JDM obd0 distributors used which usually suck $hit.
Just get OBD1 P28 and use hondata.
Old Sep 2, 2005 | 11:01 AM
Malgerus's Avatar
Default Re: PWO or PR3? im getting a new ecu... (EFSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFSiR &raquo;</TD></TR><TR><TD CLASS="quote">SAVE your money. Get it right the first time and forget about upgrading down the road.... and all the bs with the JDM obd0 distributors used which usually suck $hit.
Just get OBD1 P28 and use hondata. </TD></TR></TABLE>
I went OBD-I and used a chipped P06. I use Uberdata for my tuning, but I also have a wideband 02 sensor which really helped. It was pretty much vital for my new LS/VTEC.
If anyone wants a good B16A OBD-I bin, I can help you out. I have one that I ran a 14.1@99 with.
