ball joint press tool - anyone use one ?
Old Aug 29, 2005 | 11:16 AM
7808's Avatar
Default ball joint press tool - anyone use one ?
i have a 90 accord and im trying to replace the lower ball joint, it seem like theres not enough room on top of the part to fit the ring part on the outside of the joint, like its right up against the hub
i have the axle pulled out and everything..
Old Aug 29, 2005 | 12:46 PM
raceACCORDingly's Avatar
who needs special tool when gravity can do it...
http://www.we-todd-did-racing....5NTQx
https://honda-tech.com/zerothread?id=887859
Old Aug 29, 2005 | 01:23 PM
7808's Avatar
Default Re: (raceACCORDingly)
thats a cool trick but, i have no problems seperating those, i'm tryin to replace the ball joint, i cant get the fukin though out, its been seperated, thast the easy part
Old Aug 29, 2005 | 02:20 PM
Default Re: (7808)
oooh i just do the whole LCA or you can bring it to get pressed out
Old Aug 29, 2005 | 06:23 PM
yardy8301's Avatar
autozone loans them. but a hammer works too
Old Aug 29, 2005 | 07:14 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: (yardy8301)
Pickle fork + hammer = separated ball joint
Old Aug 29, 2005 | 10:25 PM
tyro's Avatar
Default Re: (Vt4cPwn35)
Does your accord have the 'dust ring' on the knuckle?
Remove it, get a big socket, big vise and a hammer. Get the idea?
Just make sure to take that retaining clip off first!
Old Aug 30, 2005 | 08:29 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vt4cPwn35 &raquo;</TD></TR><TR><TD CLASS="quote">Pickle fork + hammer = separated ball joint </TD></TR></TABLE>
to get the joint off the LCA completely?
Old Aug 30, 2005 | 09:13 AM
213374U's Avatar
0x5359-0055
Community Builder
Not sure about completely but that's what I did to replace my axle
Old Aug 30, 2005 | 01:32 PM
7808's Avatar
a pickle fork aint gona get it out the knuckle ( or whatever you call it) it will pop it out the lower arm thing tho.
i said **** it and got the whole knuckle and hub from a junk yard for $30, my wheel bearings were shot anyways. that junkyard one was way easier to work with for some reason, 4lb hammer was all i needed to pop joints in/out
WhiteOnRice
Aug 18, 2024 11:11 AM
Digitalsmoke
Aug 14, 2009 08:57 PM
LaterApex
Suspension & Brakes
Oct 21, 2005 09:33 PM
Origin
Oct 22, 2003 04:28 AM
civcexcoupeblack
12
Sep 22, 2002 02:27 AM
