i know some knows this!
Old Feb 25, 2002 | 12:16 PM
4gvtec's Avatar
Default i know some knows this!d16z6 on d16a6?
i want to put a 95 d16z6 in take on my 91 si hatch.there is one sensor that is not on the 95 but is on the 91. its the fast idle control selonoid,has anyone done this??
[Modified by 4gvtec, 9:17 PM 2/25/2002]
[Modified by 4gvtec, 12:05 AM 2/26/2002]
Old Feb 25, 2002 | 12:32 PM
l's Avatar
l
Default Re: i know some knows this!d16z6 on d16a6? (4gvtec)
air intake temp. sensor??
Old Feb 25, 2002 | 12:40 PM
4gvtec's Avatar
Default Re: i know some knows this!d16z6 on d16a6? (IM ALL SHO)
no, the z6 intake has that-.not the other sensor.it has tps sensor,air temp,and iac sensor.on down the forum some one else asked this same question.
Old Feb 25, 2002 | 01:06 PM
4gvtec's Avatar
i called my buddy at the dealer he said the sensor is the fast idle selonoid.he said on 92 and up its programmed in the ecu.do you just leave this undone?im sure it would make the check eng light stay on.
Old Feb 25, 2002 | 02:00 PM
D-Man's Avatar
hey 4gvtec,im gonna either try an make an plate with a vacuum nipple on it or tap and tread an nipple directly into the sensor,then im gonna connected to a vacuum source,hopefully itll work and not set off a light.
Old Feb 25, 2002 | 02:52 PM
SiR Kid's Avatar
New User
Default Re: i know some knows this!d16z6 on d16a6? (D-Man)
Put your 91 intake/throttle body on the z6
Wouldn't that fix it?
Old Feb 25, 2002 | 03:00 PM
4gvtec's Avatar
Default Re: i know some knows this!d16z6 on d16a6? (SiR Kid)
im trying to see if anyone has used a z6 intake throttle body on a 88-91 civic si.every thing plugs in except ,the z6 dont have a fast idle control selonoid on the back of the intake like the 88-91 si does.
[Modified by 4gvtec, 12:01 AM 2/26/2002]
Old Feb 26, 2002 | 05:43 AM
D-Man's Avatar
already have 91 intake/throttle on it,swapping to Z6 cause Z6 manifold has bigger ports
elli
Jun 1, 2010 01:22 PM
NhlMatt420
Jan 7, 2009 04:44 PM
wkdalpha
Feb 15, 2006 08:55 PM
lintondoza
Mar 11, 2005 07:26 PM
4gvtec
14
Feb 27, 2002 05:27 AM
