weird noise when i hit 6000 RPM than check engine light
Old Aug 29, 2005 | 01:55 AM
idriveadelsol7's Avatar
Default weird noise when i hit 6000 RPM than check engine light
this sound: when you place together your positive and negative terminals you get this cracking noise (without the sparks). i get that same noise when i hit 6000 RPM in every gear and a check engine light.
6000 RPMs - 1st gear - check engine light - reset
6000 RPMs - 2nd gear - check engine light - reset
6000 RPMs - 3rd gear - check engine light - reset and so on onto 5th
it happened after i wired my vtec lines. i'm getting a check engine light but i have no idea how to read it.
Modified by idriveadelsol7 at 3:23 AM 8/29/2005
Old Aug 29, 2005 | 06:39 AM
93CX's Avatar
Default Re: weird noise when i hit 6000 RPM than check engine light (idriveadelsol7)
sounds like vtec pressure switch
Old Aug 29, 2005 | 10:23 AM
Default Re: weird noise when i hit 6000 RPM than check engine light (93CX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CX &raquo;</TD></TR><TR><TD CLASS="quote">sounds like vtec pressure switch</TD></TR></TABLE>
what does that mean? i'm wired incorrectly?
Old Aug 29, 2005 | 10:25 AM
dohcMONSTER's Avatar
did you check the code that you are throwing? PM me if you need some more help.
Old Aug 29, 2005 | 10:42 AM
Default Re: weird noise when i hit 6000 RPM than check engine light (dohcMONSTER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcMONSTER &raquo;</TD></TR><TR><TD CLASS="quote">did you check the code that you are throwing? PM me if you need some more help.</TD></TR></TABLE>
don't know how to check codes. my friend did it for me last time...
Old Aug 29, 2005 | 11:44 AM
FalkenSiR's Avatar
Check stickes up at the top of the page
Old Aug 29, 2005 | 01:13 PM
Default Re: weird noise when i hit 6000 RPM than check engine light (fast88std)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std &raquo;</TD></TR><TR><TD CLASS="quote">Check stickes up at the top of the page </TD></TR></TABLE>
just saw it... gonna do it right now...
widewhite
Nov 20, 2014 03:49 PM
95jdmdc2
Engine Management and Tuning
Aug 9, 2008 07:52 PM
wernhersey
10
Feb 20, 2007 04:55 PM
Hail2mee2
Jun 3, 2005 05:40 AM
