Gas milage....stock B16 sirII & stock B20VTEC
Old Aug 28, 2005 | 11:35 PM
eXcelonTypeR's Avatar
Default Gas milage....stock B16 sirII & stock B20VTEC
Just curious did anyone lose, gain, stay the same in gas milage going from a stock JDM B16 swap to a stock B20VTEC swap using a B16 head and tranny in an EG??
Old Aug 29, 2005 | 02:14 AM
jdmoutkast's Avatar
b20 uses a larger bore, ie larger displacement, you need more fuel to burn in the combustion process. so theoretically yes gase mileage is going to take a hit. I'm not even factoring larger fuel flowing applications as well such as injectors, pump, etc
Old Aug 29, 2005 | 02:47 AM
SkRiBLaH's Avatar
Default Re: (EFoutkast)
highway miles = 36mpg
city/highway / ripping it every now and then = 32mpg
jdm b16a / gsr cams / itr manifold
Old Aug 29, 2005 | 08:44 AM
Nay's Avatar
Nay
Default Re: Gas milage....stock B16 sirII & stock B20VTEC (eXcelonTypeR)
I just did the exact swap. Went from a JDM B16 to a B20 block, same head. Needed bigger injectors. Said and done I went from 425KM per tank to 350KM per tank.
Old Aug 29, 2005 | 10:43 PM
Default Re: Gas milage....stock B16 sirII & stock B20VTEC (Nay)
Wow that big of a drop, did you used the B16 tranny or a GSR one?
Old Aug 30, 2005 | 08:40 AM
Nay's Avatar
Nay
B16 tranny
93whiteg6
25
Jan 10, 2014 11:30 AM
sts555
15
Jul 12, 2011 01:27 PM
CRX MASE
Sep 17, 2006 01:09 PM
AudioXtremes
12
Jan 16, 2002 06:07 AM
