Tire screeching while turning at low speeds
Old Aug 28, 2005 | 11:22 PM
Shinbo's Avatar
Default Tire screeching while turning at low speeds
This is regarding my 2004 coupe. Like the title suggests, I can hear light screeching (basically chirps) when I turn at low speeds. Obviously, it gets worse at higher speeds. Is this normal? Now I have no upgrades on suspension on this car, i'm running stock springs, shocks, and wheels.
And my driving style is pretty conservative. I rarely rev beyond 3000RPM before I shift, and I never gun it when the light turns green.
Old Aug 29, 2005 | 12:57 AM
goowakjai
Guest
Posts: n/a
Default Re: Tire screeching while turning at low speeds (Shinbo)
how do u take ur turns? do u take them real sharp? if ur driving style is real normal then...what kind of roads does this happen on? if its all types of roads maybe its ur tires...maybe there defective, i dunno...then seen this prob before, but it sounds like its prob sumthing real simple to fix
Old Aug 29, 2005 | 01:59 AM
teler86's Avatar
Default Re: Tire screeching while turning at low speeds (goowakjai)
probobly nothing but i would have an allingment done just in case
Old Aug 29, 2005 | 04:39 AM
P_Adams's Avatar
Alignment?, Yes.
You're experiencing excessive toe-out (insufficient toe -in)
The inside tire unloads on a turn, and with unsufficient toe-in trys to turn sharper than it bretheren on the outside. The screeching noise will get louder (or do it more frequently) when you drive over painted lines and smooth(er) pavement.
If it were the outside tire, you'd hear a noise more akin to scrubbing (deeper tone)
P
Old Aug 29, 2005 | 05:06 AM
deserthonda's Avatar
make sure your tires are properly inflated before alignment
Old Aug 29, 2005 | 12:14 PM
Shinbo's Avatar
Default Re: (deserthonda)
thanks for the input guys. I'll get an alignment done as soon as i can.
hawksftball2007
11
Feb 20, 2012 10:25 AM
phan
Feb 1, 2007 05:38 PM
94teggyls
Mar 18, 2003 11:08 PM
