Little mystery hose
Old Aug 28, 2005 | 09:08 PM
KaoSyN's Avatar
Default Little mystery hose
Aight so Im putting in some oil into my car since it enjoys burning it and I was just looking around when I notice this little hose sticking out of nowhere. I found it kinda strange I've never noticed it since Ive had the car. It's not really effecting the car I dont think, and Im not getting any CELs or anything. Im just curious as to what it is since I cant see where it could connect to, the only thing I can think of is maybe it was connnected to something I removed when I took off the resonator and just forgot about it. Anybody know?
Old Aug 28, 2005 | 09:13 PM
specialedition's Avatar
Default Re: Little mystery hose (KaoSyN)
I have one of those too is it coming off the transmission I think it may be a cooling tube cause they used the same tranny housing as the autos do.. so they plug the holes on the 5 spds and use the plugs on the autos....
Old Aug 29, 2005 | 03:16 AM
dc2integra's Avatar
try following it back to wherever it's hooked up? get the helms manual out and figure it out
Old Aug 29, 2005 | 10:55 AM
eluder33's Avatar
its a vent tube for the tranny. I tried putting a cover over it and when I took the cover off it sounded like I was letting air out of a tire!! Also capping it will make your tranny seals leak due to the excess pressure, mine did. I use that tube to fill up with tranny fluid, too.
Old Aug 29, 2005 | 07:11 PM
Ideal's Avatar
Default Re: (dale gribble)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dale gribble &raquo;</TD></TR><TR><TD CLASS="quote">its a vent tube for the tranny. I tried putting a cover over it and when I took the cover off it sounded like I was letting air out of a tire!! Also capping it will make your tranny seals leak due to the excess pressure, mine did. I use that tube to fill up with tranny fluid, too.</TD></TR></TABLE>
wow... if that works itl save me alot of time on a tranny refill...
Old Aug 29, 2005 | 08:55 PM
jdmlude_dude's Avatar
Default Re: (Ideal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dale gribble &raquo;</TD></TR><TR><TD CLASS="quote">its a vent tube for the tranny. </TD></TR></TABLE>
indeed it is. nothing special about it. just a vent and a good way to add tranny oil.
Old Aug 30, 2005 | 02:46 PM
machine4321's Avatar
before peps start adding oil in there make sure the spot where you normalyy add the fluid is out ...if the axels and tha filler olt are it will take days to fill....or do liek i did and tape a funnel (steal it form yoiur wifes kitchen) stick in it the funnle blow a bit . once its free of oil suck on the straw till you cant suck no more and the vacc will pull the oil n faster then you can poor it
draxxus07
Sep 27, 2005 06:39 PM
Silvteg95
Aug 14, 2005 12:37 PM
boosted_zc
May 21, 2003 07:20 PM
streakz
Dec 18, 2002 07:46 AM
dallandra
May 5, 2002 02:45 PM
