88 integra 4 dr sway bars
okay so at the local wreckers there is an 88 integra 4 door that has the front and rear sway bars on it still. I remember reading somewhere that BOTH front and rear sway bars from an 89 integra 4 door will bolt up onto a 90 crx si.
Is this true? Can I use the bars from an 88 (not 89) teg 4 door at the wreckers?
I'm assuming I need the bushings and such and probably all the hardware attached to the sway bar.
I want a perfect fit and I'm hoping the bars from the 88 teg 4 door are in fact thicker and thus will stiffen my rex up a bit.
Thanks
Thanks
so you're saying that my friend's 92 integra GS rear sway bar will simply bolt into my crx si rear end?
I have a 90 crx si and I'm not sure if his factory sway bar is bigger.
Do I need the teg hardware too or can I reuse the crx si bushings/brackets and such?
Thanks
Thanks
believe it or not, the 2 door DA integra has a smaller rear sway bar than the CRX Si. only the 4dr integra has a bigger swaybar, but only marginally. 15 vs 15.4mm
so its not worth it. but the front sway bar is 23mm hollow vs CRX DX/Si 18mm solid.
ShagginJet
Aug 27, 2003 10:00 AM
juicy.koreans.suck
Jun 5, 2002 06:58 AM
