1997 Civic gas tank.
Old Aug 28, 2005 | 08:21 PM
Under The Sofa's Avatar
Default 1997 Civic gas tank.
I actually, did do a bit of searching, and coulnt find out how many gallons a 1997 civic holds.
IM guessing around 10 gallons, which would give you arounf 380 hwy miles. But I could be wrong.
Can anyone be a pal and help a bit?
Old Aug 28, 2005 | 08:28 PM
mike93eh
Guest
Posts: n/a
i think its more like 11 something... look in your owners manual.
Old Aug 28, 2005 | 08:29 PM
EK k kay's Avatar
Default Re: (mike93eh)
11.9
Old Aug 28, 2005 | 08:30 PM
Thats the thing, I donthave an owners manual.
And I'am soon to be the proud owner of a 97 civak!.
But my padre wants me to price everything out, down to gas.
Also, dop you guys know what parts usually break on hondas. I will be keeping it stock, except for an exhaust, and maybe a short shifter.
Old Aug 28, 2005 | 08:48 PM
sicky's Avatar
grammer nawzi
Default Re: (chowmien)
That's what my manual says, as well. But, one time I somehow put 12.4 gallons of gas. . .guess I was low.
Old Aug 28, 2005 | 09:47 PM
808_si's Avatar
my tank holds around 10 gallons, i think i got some junk in my trunk
Old Aug 28, 2005 | 10:34 PM
SiKid86's Avatar
Default Re: (808_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 808_si &raquo;</TD></TR><TR><TD CLASS="quote">my tank holds around 10 gallons, i think i got some junk in my trunk</TD></TR></TABLE> same on my 99 si
Old Aug 28, 2005 | 11:10 PM
Redline96LX's Avatar
* B A N N E D *
Default Re: (SiKid86)
96-00 Civics (ex. Civic GX natural gas), CDM 97-00 Acura EL, JDM Civic Type-R EK9
11.9 Gal tank
Verified by my Helms manual and AHM
Old Aug 28, 2005 | 11:39 PM
92ehatch's Avatar
Default Re: (Redline96LX)
11.9 gallons, from http://www.edmunds.com
Old Aug 29, 2005 | 01:25 AM
FuNkDrSpOt's Avatar
Default Re: (93egsedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egsedan &raquo;</TD></TR><TR><TD CLASS="quote">11.9 gallons, from http://www.edmunds.com</TD></TR></TABLE>
Ive seen where it holds 11.9 but mine only gets 11. The gas light comes on at about 10 gal. so i doubt there's an extra 2 gal. in there.
Old Aug 29, 2005 | 01:26 AM
FuNkDrSpOt's Avatar
Default Re: (sicky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicky &raquo;</TD></TR><TR><TD CLASS="quote">That's what my manual says, as well. But, one time I somehow put 12.4 gallons of gas. . .guess I was low.</TD></TR></TABLE>
overfill probably.
Old Aug 29, 2005 | 02:23 AM
Imadisgrace's Avatar
Default Re: (FuNkDrSpOt)
Most cars...I have owned a few nissans a couple toyotas a honda and a few various others....anyway most cars have a couple gallons extra in the tank even when the gas gauge is below empty just to keep you from running out of gas. Also You can't run your car till the tank is actually empty. The fuel pickup is not on the bottom of the tank it is just above the bottom. Soooo if you have less than 1/2 to 1/4 of a gallon of gas left in the tank your fuel pump would be sucking air and your car would stop running. So yea even if your "stated" gas tank capacity is 11.9 gallons your not going to get that much into the tank at the gas station unless you keep filling it till gas is splashing out.
Old Aug 29, 2005 | 08:49 AM
92ehatch's Avatar
Default Re: (SloDelSol)
my eg says it has 11.9 gallon, i think the most ive put in it is 10.2 and thats with the needle below the E
Old Aug 29, 2005 | 08:54 AM
JDM-97CX's Avatar
Default Re: (Under The Sofa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Under The Sofa &raquo;</TD></TR><TR><TD CLASS="quote"> and maybe a short shifter.
Then I'd start saving for a transmission right now.
Old Aug 29, 2005 | 12:10 PM
* B A N N E D *
Default Re: (JDM-97CX)
please dont start the short shifter debate on here, PM me and ILL tell you all you need to know.
The fuel pump will not draw exactly 11.9 gallons out im sure. On our car, the fuel pump is sort of lubricated by the gasoline itself, so dont drive till the light comes on all the time. driving the car till it stalls cause of no fuel is not good for the fuel pump, and can put wear on parts of it. So don't drive that low anyway, I gas up at about 1/4 of a tank most of the time and have no problem with going about 300 miles a tank.
Old Aug 29, 2005 | 12:12 PM
dremmel's Avatar
would a TEG tank fit? those are a lil bigger right?
Old Aug 29, 2005 | 12:26 PM
1dayCivic's Avatar
I was told that it was 10 gallons with a 1 gallon reserve tank.
Old Aug 29, 2005 | 02:02 PM
mike93eh
Guest
Posts: n/a
Default Re: (1dayCivic)
well when its on E you probably have about a gallon left.
Old Aug 29, 2005 | 02:40 PM
FuNkDrSpOt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh &raquo;</TD></TR><TR><TD CLASS="quote">well when its on E you probably have about a gallon left.</TD></TR></TABLE>
E= another 15 miles : )
kornerk12
Jun 24, 2007 07:55 PM
civiccrazy93
Nov 16, 2004 12:06 PM
Atlas
May 26, 2004 10:33 PM
Murphy48
Acura TL, RL & ZDX
Mar 14, 2004 06:56 PM
E Swift
Mar 8, 2003 02:58 PM
