popping noise from right rear when turning right
i hear a popping noise when turning right and ive looked at the suspension and didnt see anything out of the ordinary. i thought it was my bsq + itr swaybar that caused the noise so i replaced it whith a comptech setup. now, it still makes the noise, any ideas what it could be? when i was driving without a rear sway bar, there was no popping sound when turning.
What kind of shock/spring setup do you have?
coilover setups with springs that aren't OEM style will make noise while cornering from the spring moving around.
tsk tsk tsk, i was swapping my springs from front to back and what do i see, endlink bolts that conntect to the sway bar on the left rear is missing.
as for my setup
grond control + koni yellow 500lbs rear 400 front 8" equal length springs on all four.
ill get that taken care of and ill see if the popping continues.
as for my setup
distortedfuture
26
Feb 4, 2004 12:13 AM
