Injector setup for my buddies H22 swap with chipped obd1 ecu?
Old Aug 28, 2005 | 05:43 PM
Treblarefils's Avatar
Default Injector setup for my buddies H22 swap with chipped obd1 ecu?
Well my friend has an H22 swap in a 1997 civic hatch we want to run some management setup on the car like my uberdata turbo setup. He is going to be getting a chipped p28 ecu and run an H22 rom of some sort on it. The main question is what type of injectors to use to my knowledge stock 1997 prelude injectors will not work since they are peak and hold will not work with p28 ecu. He has an old 1992 accord with the 2.2 liter could those injectors be used and does anybody know what type and size these injectors are? Would it be ok to use say 240cc injectors on an h22? We are basicly trying to get this done cheaply thats why im asking i realize he could get a set of RCs and be cool with it but we are trying to utilize parts we have laying around.
Old Nov 23, 2005 | 06:59 AM
SoySauc3 H22atch's Avatar
Default Re: Injector setup for my buddies H22 swap with chipped obd1 ecu? (Treblarefils)
im at the same part in my swap right now... i have the h22 in my ek right now and im throwing in a chipped p28...I have been told by the ppl doing my swap that I need to buy a resistor box for the injectors... and you wont have to replace the injectors... ummm i think you can get a resistor box out of an old crx or something
Old Nov 23, 2005 | 07:09 AM
Default Re: Injector setup for my buddies H22 swap with chipped obd1 ecu? (eLusiveH22 Ek4)
https://honda-tech.com/zero...ottom
check that out might help you out lolz helped me a lil
H22 SL33P3R
Nov 4, 2014 10:52 AM
CD5Accord_Corey
Jul 6, 2011 04:02 PM
eruktion
12
Jul 1, 2010 12:24 AM
crispynuggets
33
Jan 25, 2008 01:42 PM
Blown90hatcH
Jun 30, 2002 07:28 AM
