need ecu pinout diagram
help. need ecu pinout diagram. I know that three plugs are A, B, and C but which is which and how does the numbering go?
Technical question:
Hasport says to wire the 2nd O2 sensor for a b16 to wire C8. Is there an existing wire at C8 that needs to be cut?
Technical question:
yes it goes in order. left to right a-b-c-plug. all the top rows are odd numbers.bottom row is even.say like an 91 si [A] plug for the fuel injectors on the top row is- a1 is #1 inj- a3 is #2 -a5 is #3- a7 is #4.hpoe this helps.dont know about c-8 .
[Modified by 4gvtec, 2:17 AM 2/26/2002]
