93 Accord 2.2 L - Oil on spark plugs in #2 and #3 cylinder
Old Aug 28, 2005 | 03:31 PM
pickfive's Avatar
Default 93 Accord 2.2 L - Oil on spark plugs in #2 and #3 cylinders
I changed the spark plugs in my 93 Accord LX (US mfr.), 2.2 L - 4 cylinder, auto transmission, 76,600 miles. The old plugs in cylinders #1 and #4 were clean but the spark plugs in cylinders #2 and #3 were covered with oil. There is no oil in the spark plug tubes. What's the problem?
The car runs smooth so I don't know what's wrong.
Old Aug 28, 2005 | 04:47 PM
deserthonda's Avatar
Default Re: 93 Accord 2.2 L - Oil on spark plugs in #2 and #3 cylinders (pickfive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pickfive &raquo;</TD></TR><TR><TD CLASS="quote">I changed the spark plugs in my 93 Accord LX (US mfr.), 2.2 L - 4 cylinder, auto transmission, 76,600 miles. The old plugs in cylinders #1 and #4 were clean but the spark plugs in cylinders #2 and #3 were covered with oil. There is no oil in the spark plug tubes. What's the problem?
The car runs smooth so I don't know what's wrong.</TD></TR></TABLE>
something i don't understand clearly ...you say # 2 and #3 are covered with oil , but there is no oil in tubes when you pulled the plug wires off??? were the plugs oil fouled when you took them out??..
Old Aug 28, 2005 | 05:17 PM
pickfive's Avatar
Default Re: 93 Accord 2.2 L - Oil on spark plugs in #2 and #3 cylinders (deserthonda)
Yes, the old plugs were oil fouled when I took them out. There was a slight trace of oil at the end of the plug wires where they met the old spark plugs but definitely no accumulation of oil in the tubes. I installed the new plugs, drove the car for five miles or so, let it cool down and then pulled out the two new plugs in the #2 and #3 cylinders. The threads on the new spark plugs had some oil on them while the spark end of the plugs were clean. Perhaps this oil was residue from the oil on the old plugs? Is there some type of seal or o-ring where the threads on the spark plug seat to the engine?
I'm hoping this isn't a big problem. To repeat, the car runs well with no apparent problems. Should I start with a compression check or ???
Old Aug 28, 2005 | 05:32 PM
shinlegion's Avatar
No harm in a compression check...but if the car runs well and no issues, all the better.
Old Aug 28, 2005 | 05:36 PM
you could have worn valve seals in which case a compression test will not tell you anything and if ur car runs smooth most likely u got a good compression but do 1 anyways also if the plus were such oil fouled the engine should have a miss ..mmm
kain9i6
Mar 15, 2012 09:53 AM
LAO
Dec 14, 2007 07:36 PM
Midori Green
15
May 25, 2007 12:39 PM
LARRY
Feb 9, 2003 02:27 AM
PressurizedSi
Nov 29, 2002 03:48 AM
