what amount ofvoltage should i be running to the fuel injectors for a 91 b18a1?
Old Aug 28, 2005 | 10:38 AM
shaggyb18's Avatar
Default what amount ofvoltage should i be running to the fuel injectors for a 91 b18a1?
Im having a problem. i dont know how many volts it takes to run the feul injectors. I put a 91b18a1 motor into a 92 civic hatch and its not getting fuel into the motor, but the fuel is comming to the fuel rail. im assumeing its because of low voltage to the fuel injectors there not spraying. can anyone help me..
Old Aug 28, 2005 | 10:43 AM
95dxhatch's Avatar
you want whatever battery voltage is which is around 12v or so
Old Aug 28, 2005 | 08:04 PM
shaggyb18's Avatar
Default Re: (95dxhatch)
Well, i got the motor started useing carb cleaner down the intake. so i pulled the injectors and im not getting any fuel from them. could i have the wrong computer?
Old Aug 9, 2025 | 05:33 PM
whiterice916's Avatar
10 Year Member
Default Re: what amount ofvoltage should i be running to the fuel injectors for a 91 b18a1?
Just wondering what your problem ending up being. Im going through the same thing and now, the last time I tried, the fuel pump decided not to work.....that i just installed
itsukivr6
Aug 22, 2015 07:22 AM
85
Honda Motorcycles
Feb 13, 2007 08:30 AM
Sinner
Jun 8, 2003 03:03 PM
B18C-RnVA
Apr 21, 2002 09:13 PM
baonest
Aug 5, 2001 02:51 PM
