Gear oil question
Old Aug 28, 2005 | 03:36 AM
hondahatchgsr's Avatar
Default Gear oil question
Im going to be doing a tranny fluid change but when I bought my car it did not have a manual or anything giving me measurments and what not. I have a GSR swap with the GSR tranny in my EK. Anyone know what kind of fluid is supposed to be used and how much?
Old Aug 28, 2005 | 05:08 AM
jdm4life!'s Avatar
honda reccomends that you use only honda trasmission fluid. i dont know how much the gsr tranny takes but when you buy the fluid im sure the tech guys can tell you.
Old Aug 28, 2005 | 05:19 AM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: (jdm4life!)
2.9 qt for b series
1.8 qt for d series
I'd get syncromesh because it is smoother than honda mtf
Old Aug 28, 2005 | 01:01 PM
EK45VTi's Avatar
Default Re: (MugenHonda)
Honda MTF all the way... if you're grinding any gear, then go with GM Syncromesh friction modified...
But if you're not grinding then Honda MTF is your best bet...
Old Aug 28, 2005 | 05:02 PM
Default Re: (KKVTi)
I have heard of people using that syncromesh but I have never seen it at any parts stores or what not. Can you order it offline or am I just over looking it somewhere.
Also im guessing that you can just go to a Honda dealer and get the tranny fluid that they recommend right? This is my first Honda, I have always been a Mazda guy.
Thanks for the replies so far!
Matt
Old Aug 30, 2005 | 07:10 PM
Bror Jace's Avatar
Default Re: (hondahatchgsr)
Honda MTF is more-or-less a "tweaked" motor oil with a heavier additive package than you find in today's SJ, SL or SM motor oils. It also may be friction-modified.
But, best to use a full synthetic oil ... especially if you are up north where it gets really cold during the winter.
GM syncromesh fluid is available through GM dealerships ... but it is a thin fluid ... about 25-30% too thin for most Honda manual trannies. Red Line MTL is thicker (and I used to use it a lot) ... but Specialty Formulations MTL-P is close to ideal:
http://www.specialtyformulatio...5.htm
krazycivic4u
Jun 3, 2006 08:18 PM
RopethisS2K
May 3, 2006 10:11 PM
G-reX
11
Mar 19, 2003 08:20 AM
Nameless RB26
Jan 23, 2003 08:24 PM
Money Hou$e
Apr 24, 2002 04:46 PM
