Are CRX fans pusher or puller fans?
Old Aug 27, 2005 | 09:38 PM
BoostdRex's Avatar
Default Are CRX fans pusher or puller fans?
Please let me know the answer to this question. Because I may have found the answer to why my CRX is overheating since I put the EG radiator into my car... Maybe I wired it wrong?
Topic:
How are stock Honda fans designed to be run?
Here is why I ask:
When I pulled the stock radiator fan, and I put in the EG radiator (using the EG's fan), I wired the fan as it was on my stock CRX fan harness, blue for blue, and black for black (matching the black and blue wires on the EG radiator with my CRX's black/blue fan harness...)
I noticed that the fan pushes forward when parked. I got to thinking that perhaps it's supposed to pull air. Is this correct? Because if that's the case, then I have wired it wrong, and that would explain why when I am driving, my car would get hot, and not cool down until I come to a stop. Come to think about it, that is when things started to get hot, is when I put that radiator in.
It's when I am driving that it gets hot, therefore making the air shooting into my radiator, become hot because the fan is blowing the opposite direction.
What does everything think? How are these fans designed to be run? Push forward through the radiator? Or pull air into the engine bay? It would just seem weird that it is designed to push forward if the air is being shoved in the opposite direction when driving...
Please let me know if this is my issue?
My overheating issue:
https://honda-tech.com/zero...52670
Modified by BoostdRex at 11:00 PM 8/27/2005
Old Aug 27, 2005 | 09:59 PM
BoostdRex's Avatar
Default Re: Are CRX fans pusher or puller fans? (BoostdRex)
anyone?
Old Aug 27, 2005 | 10:26 PM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostdRex &raquo;</TD></TR><TR><TD CLASS="quote">It would just seem weird that it is designed to push forward if the air is being shoved in the opposite direction when driving...
It would, wouldn't it... It would also seem wierd that it would take the hot air off the exhaust and blow it over the radiator. It's a puller fan, reverse the wires and it will work a whole lot better.
user 72830283
Mar 1, 2015 02:40 PM
arrojj
Sep 3, 2008 08:56 PM
jdmspoonitr
Oct 3, 2006 10:46 AM
BoostdRex
Aug 27, 2005 10:04 PM
RacerBoy
Jul 3, 2003 11:27 AM
