B20 SWAP INTO HF
I HAVE A 88 CRX AND ITS CONVERTED TO FUEL INJECTION. IM THINKIN OF PUTTING A B20 SWAP. WHAT TYPE OF HARNESS DO I NEED? I KNOW I NEED TO REPLACE THE B20 MANIFOLD WITH THE B18 MANIFOLD. AND ALSO IM PUTTING A LS TRANNY. IVE ALREADY GOT THE MOTOR MOUNTS. WHAT ELSE DO I HAVE TO DO? HAS ANYONE EVER DONE THIS SWAP? IF SO HOW DID IT GO?
FYI using all CAPS is considered SHOUTING take off caps lock or people will flame you. But, as said before do a search this subject has been covered before
look in the upper right hand corner of your screen. there is a search option. and in case that doesn't work for you, try here........https://honda-tech.com/zerosearch
not meaning to flame at all but this subject has been covered numerous time before.
