Dpfi to Mpfi converson timing problem
Old Aug 27, 2005 | 05:27 PM
esteen2's Avatar
Default Dpfi to Mpfi converson timing problem
I have a built d16a6 in an 88 std hatch I converted to mpfi and now motor cranks and runs but has 50 deg. of timing also throws code 9 sometimes. I have checked cam timing and it is correct. Any help please ?
Old Aug 27, 2005 | 06:20 PM
suspendedHatch's Avatar
Default Re: Dpfi to Mpfi converson timing problem (S2R Honda)
These may be stupid responses but are you using the spark plug wire coming off the plug that is closest to the crank pulley? Is the crank pulley mounted right using the chuck key? You know Honda engines rotate backwards?
By built do you mean adjustable cam gear, aftermarket ignition, deck shaved?
Which code is 9? I'm too lazy to get the repair manual out of the garage but if you retrieved the code you should already know what it is.
It runs but does it run well?
Old Aug 28, 2005 | 03:03 PM
esteen2's Avatar
Default Re: Dpfi to Mpfi converson timing problem (suspendedHatch)
the motor was built by DFE Enterprises, it has a ported head, 1mm oversized valves, Web cam, Ferrea rods, JE pistons, and is balanced. The code is for the cylinder position sensor, and I am using the #1 wire to check the timing. I have also checked to make sure the timing belt is not off a tooth. I am getting a new distributor tomorrow hope it works ?
Old Aug 28, 2005 | 04:16 PM
I think that fixing the code is the most obvious solution. Start there.
tautog
Apr 2, 2017 01:51 PM
2010coupe
Oct 31, 2012 05:53 AM
trav_89_crx_b7
Sep 26, 2011 02:54 PM
tdc
Jul 21, 2002 07:54 PM
red civic standard
Jul 14, 2002 07:25 PM
