glue in driver doorlock. please help
Old Aug 27, 2005 | 02:06 PM
bmw626's Avatar
Default glue in driver doorlock. please help
some stupid ****** decided to put glue in my driver doorlock (idk why they didn't do the paggenger) and i dont know how to get the **** out, and i have no alarm system on my car and i have to crawl through my passenger side to get in now. Is there anyways to get it out or do i have to buy new locked and have them rekeyed or what? This is bullshit, someone needs to die for this one....
Old Aug 27, 2005 | 02:16 PM
v8rx7's Avatar
Default Re: glue in driver doorlock. please help (bmw626)
super glue? hot glue? elmers glue?
It all depends on the glue, I know from interning as a med res. that acetone eats super glue. As wel as mineral spirits.
If its elmers glue, use you garden hose and spray that sucker clean.
Hot glue, use a razor or needle to clean that sucker out.
Once you have done on of the above go to your local wal-mart and buy the lock graphite **** and re lube your lock.
Hope that helps
Old Aug 27, 2005 | 02:33 PM
SlowHX's Avatar
Try using a lighter on your key to heat it up and jamming the sucker in the doorlock. works when my locks freeze in the winter
Old Aug 27, 2005 | 02:43 PM
transpar_nt's Avatar
Remove the lock cylinder from the door and squirt some acetone in there, rinse it out, and repeat until clean. Next, find out who did it and fill their mouth with glue.
Old Aug 27, 2005 | 05:33 PM
rabius's Avatar
watch the paint though if you leave straight acetone or mineral spirits on it too long, you will have a nasty streak.
Old Aug 27, 2005 | 05:51 PM
Sketch_hs's Avatar
have fun hurting the person that did this when you find them.
Old Aug 28, 2005 | 04:29 PM
bmw626's Avatar
Default Re: (Sketch_hs)
thx guys, the acetone worked after about 3 cleanings, now its time to find the bastard taht did this.....
integracura
Nov 12, 2006 09:15 AM
cilvia
26
Feb 7, 2006 06:48 PM
etmoron
15
Jun 11, 2003 05:00 PM
gsr.sedan
Jun 7, 2001 01:36 AM
