PUTTING NATURAL GAS PISTONS IN A D16Z6
Does anyone knw all the exacts to putting the 01 civic gx natural gas pistons in a d16z6. If so please let me knw. i have heard that u have to use the ls rods but that is all i knw,i knw about the ls rods and stuff. any more info would be greatly appreciated.
thanks
me
thanks
me
it's in his web site, good stuf
http://www.heeltoeauto.com/tec...shtml
dropping in the 01 GX pistons will lower the compression as they have 3mm lower compression height............
Please, in your other posts elsewhere on here and other forums, you never mentioned you wanted to use the 01 slugs.
They might work in a D15 long rod setup, but not a 1.6L unless you use custom rods.
I'd be easier just to order some P29's and be done, cheaper too! You can find the P29's for $150-175 shipped, which is about 1/2 the cost of using the GX pistons and rings.
$250 + S&H for a set of the GX pistons and rings..........
i can get the gx pistons from honda for 34 dollars a piston, and what is the ratio on the p29's please
Modified by yellowjdmcrx at 12:27 PM 8/28/2005
DelSolDon
Apr 2, 2011 11:29 AM
yellowjdmcrx
Aug 28, 2005 09:32 AM
4door93civic
Aug 3, 2004 11:40 AM
