ugh, help pls, DX-b16 MPFI issues. Dizzy wires are confusing
Hey guys, Welp I did a Stupid move.
According to this, I have to remove the pins of the DX Dizzy plugs and plug them into a SI plug,
Because the DX plugs are Square, and the SI\b16 plugs are round.
anyways, I removed all the wires in the DX plug to put into the SI plug, and it turns out there are 2 white wires.
One is for IGN,
One is for CRANK
there both white,and both the same size, no stripes. how can I check witch is witch? I have the CRX shop manual, and its not helping.
this may help.
One is for IGN,
One is for CRANK
this may help.
dnt kno if this will help much, but its a thread for obdo-ob1 wiring. enjoy
https://honda-tech.com/zerothread?id=1349052
When I did the MPFI swap on my DX, I took out the pins of the Si plug and plugged them into the DX plug. I had two white wires, and I wasn't sure where they went, so I guessed and plugged them in one spot and the car wouldn't start, so I swapped them around and it started right up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crex23 »</TD></TR><TR><TD CLASS="quote">When I did the MPFI swap on my DX, I took out the pins of the Si plug and plugged them into the DX plug. I had two white wires, and I wasn't sure where they went, so I guessed and plugged them in one spot and the car wouldn't start, so I swapped them around and it started right up.</TD></TR></TABLE>
there we go, sounds easy enough, ill just throw them in there for now. thanks for confirming it for me.
