camber kit help.....any info would be appreciated
Old Aug 27, 2005 | 11:17 AM
zckidd's Avatar
Default camber kit help.....any info would be appreciated
ok well, i installed a camber kit that replaces the upper ball joints on the upper control arm. after beating in the under fender lip in, and pulling the arm out as far as it could go ( with the kit i got, i can pull the ball joint 3 degrese out)....i still have some camber. not to mention that my alignment is whack. (i can make one tire straight, and the other tire will look like its turning )
can someone gimme any info as to why i still have a lot of camber?
or would it be that i need an alignment and that would fix the "looks like a lot of camber" problem
jmai86
Suspension & Brakes
Jul 27, 2009 04:58 PM
hondaluver12
32
Dec 17, 2008 08:11 AM
garyc17
Suspension & Brakes
Apr 13, 2008 08:39 AM
lsvtec_DA
Feb 25, 2004 09:59 PM
Sandor
Nov 17, 2003 09:01 AM
