Tranny kick-down cable....
Old Aug 27, 2005 | 10:58 AM
Duster's Avatar
Default Tranny kick-down cable....
I just finished installing a new tranny in my 1986 honda accord and I was wondering about the adjustment of the kickdown cable.
Right now it is shifting at 4250 rpm's obvsiously high, so I need it to shift lower so i move the nuts on the kick-down cable down correct?? thanks guys
Old Aug 27, 2005 | 08:39 PM
Chiovnidca's Avatar
Default Re: Tranny kick-down cable.... (04Gixxer7K)
When you press the gas pedal at idle, the throttle pressure lever should just start to move as the rpms start to rise.
Old Aug 27, 2005 | 11:08 PM
Duster's Avatar
Default Re: Tranny kick-down cable.... (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">When you press the gas pedal at idle, the throttle pressure lever should just start to move as the rpms start to rise.</TD></TR></TABLE>
Sorry but im not quite sure what your saying, thats how i adjust my kick-down cable?
Old Aug 28, 2005 | 04:31 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 04Gixxer7K &raquo;</TD></TR><TR><TD CLASS="quote">Sorry but im not quite sure what your saying, thats how i adjust my kick-down cable? </TD></TR></TABLE>
You have to loosen the nuts on the cable above the lever to adjust it. That what you need?
Old Aug 29, 2005 | 11:37 AM
Duster's Avatar
No what i needed was to figure out which way the nuts needed to be moved in order to make the car shift at lower rpms, but i figured it out..
Old Sep 2, 2012 | 06:58 PM
rodneylynn1977's Avatar
Adjusting this cable, will it solve my hesitation or surge at 75 mph and about 3500 rpms?
Old Sep 2, 2012 | 09:02 PM
holmesnmanny's Avatar
Probably not. You could try checking your ignition timing.
civic_jason
Feb 8, 2025 06:56 AM
pmey
Dec 2, 2008 01:30 PM
redline870
Nov 13, 2008 12:43 PM
efyou
Apr 28, 2006 09:40 AM
