Eagle Rods with stock pistons?
Old Aug 27, 2005 | 10:02 AM
hotimportcrx's Avatar
Default Eagle Rods with stock pistons?
i am putting together my ls vtec turbo and i wanna know thnat since its boosted and the compression is low already on stock ls pistons ...would i be able to run with eagle rods and arp rod bolts with stock pistons...or are the stock pistons to weak????...(i am going to be trying to make it close to 350whp)
Old Aug 27, 2005 | 10:06 AM
hulkhb's Avatar
Default Re: Eagle Rods with stock pistons? (hotimportcrx)
I wouldn't bother really, just wait till you get pistons, OEM rings lands are weak, though manny have made real nice pwer with stock motors.
Old Aug 27, 2005 | 10:21 AM
boosted92's Avatar
Compression alone doesn't make for a good turbo piston. The stock ringlands on all honda B-series motors are weak and have a tendency to crack when you put a lot of power into them. Don't cheap out and spend the 400 bucks on new pistons.
Old Aug 27, 2005 | 10:33 AM
Team Evol Tyrone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotimportcrx &raquo;</TD></TR><TR><TD CLASS="quote">i am putting together my ls vtec turbo and i wanna know thnat since its boosted and the compression is low already on stock ls pistons ...would i be able to run with eagle rods and arp rod bolts with stock pistons...or are the stock pistons to weak????...(i am going to be trying to make it close to 350whp)</TD></TR></TABLE>
I would think not how you going to hold the pin in without modifying the pistons to hold locks. The part you skip out on will fail in the end and cost you a lot more money in the end.
Old Aug 27, 2005 | 11:00 AM
Default Re: Eagle Rods with stock pistons? (freakyty2)
yea because the ringlands on my b16 were destroyed.....it was a stock block running 16psi...held up for some time though...but what would be a combination of some good rods and pistons for my ls vtec turbo setup
Old Aug 27, 2005 | 11:12 AM
boosted92's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotimportcrx &raquo;</TD></TR><TR><TD CLASS="quote">yea because the ringlands on my b16 were destroyed.....it was a stock block running 16psi...held up for some time though...but what would be a combination of some good rods and pistons for my ls vtec turbo setup</TD></TR></TABLE>
Eagle rods, Wiseco pistons.
TravisBiggie
Apr 22, 2013 04:46 AM
joiv21
Jan 15, 2013 01:58 AM
LS-turboner
Jan 8, 2010 04:25 PM
all_motor_sfwd
Apr 26, 2007 09:46 PM
specie
Dec 8, 2002 09:42 PM
